Off2Geo
...deflatedDear friend,
Sorry no. The RGB brigheness of K7/K7BT is not adjustable.
Best regards
Best regards
not sure which link you visit but Official link given by Fiio shows both US and EU plug USD249.99.... UK is out of stock currentlyHello o/
Quick questions about the k7 bt:
- is there is way to see the battery level of the bluetooth device connected to it? (i use utws5 with my fiio fh7s)
- any support for mqa on the bt version? wasnt available on the regular one
- the product page says "Recommended headphone impedance 16~300Ω) however the 4.4mm output impedance is inferior to 1ohm, which according to the eight rules should be more than enough for my u12t with an impedance of 10 ohms? Could you elaborate on that?
- why does it cost 60 euros more for the EU plug on aliexpress?
- also when will it be available in Europe? the shipping cost is a tad expensive
Thank you
Also MQA went bankrupt so I doubt any new products from anyone are going to support MQA anymoreHello o/
Thank you
I assume it's taxes ?not sure which link you visit but Official link given by Fiio shows both US and EU plug USD249.99.... UK is out of stock currently
Taxes is not what they can control so your statement is not accurate enough...I assume it's taxes ?
Went to fiio official store on aliexpress
Didn't know MQA went bankrupt, good to know thanks.
People from my country have taxes auto-applied when buying on aliexpressTaxes is not what they can control so your statement is not accurate enough...
$249.99 is the base price in US without taxes.I assume it's taxes ?
Dear friend,Hello o/
Thank you
I think the OP was wanting to know (and i'm making a wild guess here) that if within the Fiio app, will it show the battery percentage of a connected BT device such as BT headphones.Dear friend,
1. The K7 BT does not have battery. So the APP will not show its battery level as well.
2. It does not support MQA.
3. Yes, theoretically, the K7 BT could drive your 10ohm headphone.
4. The VAT is included.
5. We are arranging the K7 BT to our sellers in Europe, so you may get it from the seller at about 1-2 weeks later.
Best regards
Dear friend,I think the OP was wanting to know (and i'm making a wild guess here) that if within the Fiio app, will it show the battery percentage of a connected BT device such as BT headphones.
Correct. Obviously my coffee did not have time to jump start my brain as now I look at the post I and feel like a dumbarse lolDear friend,
The K7 BT supports Bluetooth receiving instead of transmiting. So it could not connect to BT headphones and support the feature you mentioned.
Best regards
Yeah i meant displaying the level of the connected BT iems.Dear friend,
Best regards
Unless I'm interpreting it incorrectly, I don't think you can connect the UTWS5 to the K7 BT in the first place. "Bluetooth receiving" means using an external source (such as your mobile phone) to transmit music to the K7 BT. Since the K7 BT (apparently) does not support Bluetooth transmitting, that means you can only listen to music via wired connections.Yeah i meant displaying the level of the connected BT iems.
Thought it was a feature on the BTR lineup so i thought it might be present here aswell.
So there is no way to know the level of the battery of my UTSW5 if i connect them to the kt7 bt?
