So I’ve had more time with the JT1’s here’s my final findings, don’t forget it’s my ears that are hearing the findings so it’s only a guide line and not a forced opinion. Drivers have had 4 days burn in ( some believe this is needed some don’t) I’m happy with the internal mods I’ve done and have noticed a good enough difference to validate doing it with tighter bass and more separation between the sub bass and the mid bass and not just a bass thump, mids and top end are quite revealing and sound very good especially instrument separation and vocals are nice and clear and there’s no top end shrill at all, this might be due to the burn in as well as the mods / pad rolling I’ve done. Even though they are easy to drive they do scale well with a bit more power going through them, pad rolling does have quite an impact on the sound, stock pads are good with the mods see prior comments but where they seem to sound the best is using a set of Denon AH pads which give them a low end punch of tight bass and great mid bass you can hear the strum of the bass guitar and vocals have sparkle but when I swapped over to a pair of flat velours they hit a sweet spot with a refined bass not as low as the denon pads but still plenty of bass just a more refined type, you can hear the different types of bass instruments better, vocals again clear and precise and top end lush with a hint of warmth to it, they sound nicely open sounding with the velours on, basically you sacrifice a bit of low end punch but gain in everything else and I highly recommend trying out a pair of thin velours with the internals modded or not. These headphones are sold as closed back but I’d say they are more semi open which is actually a good thing as it gives them a nice bit of breathing space and doesn’t sound like your getting the music forced into your ears. Highly recommended set of headphones for the price even without any mods or pad rolling, but i definitely recommend trying the velours especially if you find the bass a bit on the heavy side in stock configuration.
Just to add the original thick angled pads I tried are a no no they give it too much boom in the bass, whatever pads you decide to roll keep the thickness to the same type as stock so your ears aren’t too far off the drivers
![IMG_1241.jpeg](https://www.head-fi.org/attachments/4638260/)
