Jujoe
I've just pre-ordered the FH7 will my symbio mandarins fit them?
Ah heck, I just sent my Symbios with the FH5 I sold .I think so but can't be certain.I've just pre-ordered the FH7 will my symbio mandarins fit them?
Yes they'll fit. Not my favourite tips but you never know, everyone's different.Thanks, fingers crossed but no biggie smalls if they dont.
You think that is the best option under 500 dollars?
And if you happen to use (or plan to use) one of FiiO’s current DAPs, I’d say without a doubt.In terms of pure sound quality & performance its up there. But if you also figure in the look and build quality, then I would say yes.
You make me the monkey ...
I still haven't received the M11 and I already think of ordering the FH7
If you factor in:
- SQ
- comfort
- fit
- build quality
- cable
- accessories
Yes.
My fav setup is the stock reference filters + stock balanced tips.
I don't think it has any mileage to cover at all. The Shures, while good, are now considered poor value for their price. Here's one impression: https://www.head-fi.org/threads/fii...yllium-dd-driver.903205/page-11#post-14984075. Add to that the superior build quality and accessories of the FH7...Though the FH7 sounds superb, it still has to cover some millage to really compete with the Shure SE846. Any impression on the comparison between two?
