TooPoorForHiFi
Previously known as MidNighTempest
3rd party Cable would work with these correct? nothing out of the ordinary? I know some Sony IEM tends to be picky with these things.
The fh5 plus es100 are a monster in balanced. Can't recommend enough the es100 with most in earsHow's the fh7 with the es100 balanced?
Thanks
@FiiO Please kindly let me know, when will you ship FH7 to your distributor in Thailand? I already pre-order and cant wait to get it. Thanks
from this dealer. Please check price from their shop in this link https://bit.ly/2XllTwn. I purchased many things from them since FiiO X3 first gen. Very good supportWhere did you pre-order it? Which store.
And how much in THB.
for these do i need an AMP or DAC?
What's your source? I am not saying you need a good DAC, but you need a good DAC. The M11 is solid.
If you look at my post above you will see how I compare them to my Share 846s.how would this compare to something like Shure 846?
also
currently gona try to upgrade to an Fiio M11
