I have both, and both of em are different sound signatures, the fiio has a more premium feel into it, whenever I can sit down and enjoy it, I just go with it, the dm7 I use it more for going out. Sound wise, the fh7 has a wider soundstage, details are way more present but not in a sibilant way (and nor does the dm7) the sub bass and bass are massive and really precise, they rumble when it’s needed, beryllium it’s an amazing material. Mide are balanced and pretty clean, the treble is quite weird to define, airiness is there but it isn’t annoying
The dm7 bass is accurate but lacks the definition and texture from the fh7, soundstage and 3D imaging aren’t as developed as the fh7 but that gives the user a more intimate experience, miss are forward and detailed with a touch of a drop getting into the highs territory, I’m coming from using the dm6 and can tell it’s a serious step forward from em, still the fh7 is a way more serious iem
Thanks a lot, you're awesome!
Last question (I promise), how is sound isolation between the two? I have a Shure se425, and it's very useful when I'm commuting or working in cafes. I wonder if fh7 would provide me a bit of that (I know shure isolation is top notch) with a way better sound quality, or if in that aspect the DM7 would be a better way to go.
Also, comfort wise, which of the two is better?
And just to see if I understood, related to different sound signatures, the DM7 is more intimate and mid forward, and the fh7 is more balanced?
Thanks for sharing your impressions, I appreciate
