- Jan 30, 2011
I don’t think you understood the point on crosstalk. Above 50db you won’t notice it - you’ll notice degradation in perceived stage as crosstalk lowers below 40 dB. And even if you’re talking 50db ......... at 15kHz - all that is there is very faint harmonics, which majority of people can’t hear anyway. Nothing which will affect perception of stage.I agree about Noise, Power & distortion - difference is negligible to notice, but (correct me if I'm wrong as it's from memory) Cross-talk however, if measured at 1K @ -73db will likely go above -50db by 15K, and the worst part is that it's uneven. Capacitance and inductance induced transfer will interfere and create multiple small scattered peaks that mask some auditory ques that otherwise help brain to re-constitute the sound stage. That theory is consistent with what I hear which is the only improvement I notice is in sound stage.
Also I believe that manufacturers are less likely to cut corners designing balanced circuits as they know that loud minority of discerning audiophiles will be using balanced. My Hiby R6 balanced output sounds a lot better than SE but only on resolving IEMs (Sony ier-M9, ibasso it04, FiiO FH7, Fearless S8Pro).
Subtle on Shure846 and Sony Z5. So part of it is of course hype and placebo effect but specifically on Xelento and FH7 with Hiby - difference is not subtle. On Ear-studio es100 it's considerably less noticeable for some reason.
BTW, sony has dsp effect to reduce cross talk, anyone has any experience with that?
What is the OI difference between SE and Bal on the R6? That may make a frequency change. If there is no freq change - what is your method for testing. How are you volume matching? Is it sighted?
I keep hearing people talk about non-subtle differences, and being associated with the fact the signal is balanced. Science tells us this can’t be the case.
