Devodonaldson
Fin goes in concha bowl of rearOk thanks . I would have to order from Aliexpress as I can’t find them on eBay .
Does the fin part go down towards the back or front of the ear?
The rubber did not alter the sound ?For anyone who’s struggling to keep these in their ears I have now tried the far end gear Budloks fins ....at the moment they are working well will have to see how comfortable they are long term. I have managed to fit a foam over the rubber.
Thank you Devodonaldson for your help if I come across the others you mentioned I will try them as well.
Not as far as I can tell. There is a small vent at the bottom so I cut a gap to keep this open.The rubber did not alter the sound ?
You can also try a few experiments I did that worked well for the most part.Not as far as I can tell. There is a small vent at the bottom so I cut a gap to keep this open.
Make sure to do the burn in. Otherwise you’ll completely miss the train. I was not a believer in that before i did it on the EM5.I was gathering funds to buy LCD2C again.
I saw EM5 available in India for the first time and I couldn't resists, pulled the trigger as soon as I saw them.
Hope they perform as well as I expected.
By the way I love earbuds way more than IEMs.
Will be waiting for it!
I feel its hard getting IEM fans to listen, myself included but @ian91 and I share music taste and both fell for Isabellae for those listening preferences - he said I need to try buds, Blur specifically and I trusted his recommendation and jumped in, definitely not looking back! Looking forward to trying Blur next.
