PTom
- Oct 20, 2013
Yup I can also increase the bass boost using the E7. I can increase the volume also using the windows volume icon not just app based.
I have to go to work now, will get back to you this evening.
EDIT: Back from work.
This is interesting stuff, I wonder what's going on.
My E9 is connected via USB to my desktop pc that's running Windows 8. The E7 is docked in the E9 (which is necessary in order for the USB DAC feature to work, for example if im listening to music on foorbar2000 and I undock the E7 it stops all sound etc).
Headphones are going to the E9 of course (left hand side 3.5mm jack port).
Just switching the E9 on doesn't automatically mean sound comes through the E9, I have to go to 'Sound' found in Control Panel and select 'Speakers - USB Audio DAC' and set as 'Default Device'. (I have other speakers in this area such as desktop and 5.1 surround sound ones which I sometimes use, so I'm used to going in this area and changing).
I can increase Bass etc through this area by clicking on Properties>Enhancements>Bass Boost>Settings and specify what I want there.
I just double checked and when Im doing all this adjusting the volume or bassboost on the E7 does nothing at all, no effect on playback volume or music.
Using the logitech multimedia volume keys does nothing (tho i can see the adjustment bar), likewise if I go bottom right hand corner to system tray and adjust volume for Windows 8 there.
I am left with only two ways to change volume, the dial on E9 or in a music app such as foobar.
Perhaps u guys can test what happens during playback if when yer headphones are connected to the E9 and yer listening to music on the computer successfully through to yer headphones, pull the E7 out, do you lose sound playback like I do?
I wonder if there are different E7s or E9's?
Ahh wait... I think u guys might be using the E09K rather than what I have which is the older version simply E9.
I'm planning on selling my E9. I don't use it at all. In fact, all I do with it is charge my E17 with it. Any one here interested?
