genclaymore
Hmm, another poster had a similar issue. Do you get hiss when turning the volume knob only and or when there is no music playing? If it's the latter then you might have a defective unit. My E9 produces a slight staticy noise only when turning the volume knob, other than that it's quite silent.
Mine started to do this as well But when nothing is playing. Some times it do not do it at all. then out the blue it starts back up.I'd open it up if i knew what screw driver to use, since I been wanting to change its op-amps.
