AUserName501
- Feb 9, 2014
Originally Posted by JamesFiiO /img/forum/go_quote.gif
1, The feedback means any advice for Q5.
2, Sure, the K3 ( E09S ) is designed for X1/X3 II/ X5 II and X7. But the X3/X5 lack of dock conector .
3, Thanks for your input about the Q5.
4, I don't know what is wrong with the result of our E17, but the result is not supported to be so poor.
I've spent some thinking about how Fiio appeals to me. I can narrow it down to these few things:
- Detailed technical specifications
- Price
- Features
- Great build quality
Here is what I think works about each Fiio product:
- The E5/6 is cheap, small and has good specs for the price.
- The E10k is a cheap DAC/Amp with a reasonable power output and good specs. The Schiit Fulla now offers some tough competition though.
- At the time I bought the E17 the only other good DAC at a reasonable price with optical input was the AudioEngine D1. The E17 was cheaper and offered a lot more functionality in a small and portable package. I can connect my E17 to my Android phone without problems as well. To this day there is nothing else like the E17. Nobody else has created a portable DAC/Amp with so many different inputs (USB/coaxial/optical/Aux). The E17k added 32/96 and DSD but neither of those features are important to me.
- The E11k/E12 packs a lot of power in a slim and portable package at a good price. The E12A is made for IEMs.
- The E18 works with many Android phones, has media control buttons and can be used as a power pack.
- The X3/X5 can be used as a USB DAC as well as a portable media player.
Most Fiio products are either at a competitive price or offer more features than their competition. Fiio always comes out on top when you consider the amount of features you get for the price. My concern is that the Q5 will break from this mold. The question is what features could be offered that competitors don't.
The only feature that I can think of at the moment that would make the Q5 unique is a parametric equaliser. At the moment I currently use the parametric equaliser called EqualizerAPO with my Sennheiser HD800 in Windows to tweak the frequency response to my liking. The problem is that it doesn't work with WASAPI or ASIO and it is limited to Windows. By moving the parametric equaliser to the DAC/Amp, instead of the operating system, it means that I can use that parametric equaliser with everything that I've got connected to DAC/Amp. It has to be parametric though because it offers greater precision than your standard graphic EQ.
I've also thought about how much of a compelling feature a parametric equaliser would add to the Fiio X3/X5 DAP. At the moment my Rockboxed Sansa Clip+ has a parametric equaliser and more functionality than any other DAP out there. If a parametric equaliser was added to the X3/X5 then I'd buy one and if the parametric equaliser would also work when the X3/X5 is connected via USB to my computer as a DAC then I would certainly buy one.
Another thing that might be of interest is a good microphone input and bluetooth with Aptx support. The Creative E5 currently has this.
If you offered some good 7.1 virtual surround sound for gaming then that may appeal to many. Plenty of gamers here with audiophile headphones. SBX Pro Studio is the most well liked. Razer Surround is software and appears as a virtual audio device which works with any USB DAC but most people dislike Razer Surround and usually prefer CMSS-3D or SBX Pro Studio because it sounds better. However, Creative doesn't have a purely software product like this at the moment.
If Fiio offered 7.1 virtual surround sound software like Razer Surround and gave it away for free when you buy a DAC/Amp/DAP from Fiio then you'll get a lot of gamers buying Fiio products. A lot of people here would be buying the Q3 or Q5 rather than the Modi/Magni as a result of that. There is a huge amount of gamers buying audiophile headphones and most of them are looking for a USB DAC/Amp to go with their first pair of audiophile headphones (usually Sennheiser HD558). I would be recommending to get to the Fiio E10k rather than the Schiit Fulla if Fiio bundled 7.1 virtual surround sound software with the E10k. 7.1 VSS is also of use to people want who want to watch movies on their laptops and as many products (E17k, E18, X3, X5) are made for portable usage then this would be of great appeal to them too. It's a feature that Fiio can offer and others like Schiit can't.
Of course there are other features that can be added such as optical, coaxial, USB and auxillary input. A pre-amp circuit for powered speakers. DSD support and 32bit/96Khz for USB decoding but plenty of competitors out there offer these features and the people interested in DSD often have far more expensive equipment anyway.
