FiiO E07K ANDES Review and Help Thread
Mar 19, 2014 at 6:04 PM Post #1,249 of 1,676
  and which are these "compatible" devices
should i reform the same question several times :D ?
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs
http://www.head-fi.org/t/507559/list-of-dacs-that-work-with-ipad
And this thread
Most of it involves using the search function on Head-Fi in these 3 threads to find posts from users with that device :/
Sorry, that is the only way.
Mar 21, 2014 at 10:48 PM Post #1,251 of 1,676
Just want to report I picked this up the other day and was surprised to find that the USB DAC works impeccably with both my Nexus 7 v2 and my Bell Samsung Galaxy SIII with Cyanogenmod 11 (Nightly 2/26/14).
Almost went with the E18 at a $50 premium for "android compatibility", glad I didn't!
Mar 22, 2014 at 3:33 AM Post #1,252 of 1,676
Yes thats why i am.asking about it
E18 seems to be special android dac
I cant really.understand why it has to be android only special case
I need it as dac because i.already have e12 as an amp
Audio tech spec seems.to be the same
Why should.someone buy e18?
It isnt even generaly compatible with androids
Mar 22, 2014 at 4:04 AM Post #1,253 of 1,676
According to ClieOS review, it is actually better if not, on par with E17 if I recall correctly. That said, the E18 is actually better than E07K in amp section. But if you wish to go triple stacks, it doesn't really matter except that the E18 looks better IMO
Correct me if I am wrong
Billson :)
Mar 22, 2014 at 4:43 AM Post #1,254 of 1,676
I dont need it as an amp
If we compare them as dac, there doesnt seem to be 80 euro extra worthy specification for E18 against E07K
Iw would say, they look both great
But you cant.compare them
Visual styles aee very different but both very good imho
Mar 22, 2014 at 5:32 AM Post #1,255 of 1,676
I assume you are going for triple stacks? xD I like seeing those xP
Mar 22, 2014 at 5:59 AM Post #1,258 of 1,676
Player would be foobar
Dac and e12 as amp
Is it somehow bad configuration or idea?
I dont get it right
So yes
My config would be tripple stack in this case
Good source data>>foobar>>some good dac>>E12>>Focal spirit classic
I have everything but DAC
Deciding between e18 and e07k
Yes,it has to be portable
