Apr 9, 2014 at 10:17 PM Post #1,277 of 1,676
generally android supports audio out on usb already since couple of years
maybe you should search for some special ROM at xda developers if original ROM doesnt support it that way
So if I flash a new rom, I may b able to play all audio out of usb?? Any guesses as to which rom for l710??
Cyanogen mod maybe?? Ive ran cm before but been with jellybomb domination for a almost a year now. Love this rom
Apr 10, 2014 at 10:21 AM Post #1,279 of 1,676
Yes if that special rom enables it
On android level it is already possible but not enabled from all producers
I have no idea which rom but if you search well.enough on.xda dev. You will.find it
Ok ill have a looksie.. im a member of that forum but havent been on in a while sinve ive been using jellybomb so long.
Looks like ill b using the "forgot my password" lol
Apr 10, 2014 at 10:33 AM Post #1,280 of 1,676
sorry,that i cant help you this way
it would be very had to find here someone who has the same phone,same dac and wants the same thing you ask for :)
only thing would be to try out but if you still find here somebod so i would wish you good luck :)
Apr 10, 2014 at 8:13 PM Post #1,281 of 1,676
Hi, does anyone know what AMP is inside the E07k? I have the E06 and the output specs are different and I know that the two do not share the same AMP so I was just wondering if anyone can provide me the model number of the amp used in the E07k. Thanks!
Apr 11, 2014 at 1:25 AM Post #1,284 of 1,676
The E07K and E6 sound similar in amp section if I am not mistaken
I was at my local headphone shop and it seems that they use different AMPs. They do sound similar though at least to me.
Apr 11, 2014 at 4:59 AM Post #1,285 of 1,676
I dont really get how do you "smell" amp from.another amp in sounding?
If amp does its job and i mean it amps, you shouldnt be able to locate difference between two different amps which do their jobs well enough in tolerance
Apr 12, 2014 at 2:36 PM Post #1,286 of 1,676
Well ideally an amp should be neutral. Reality is that they do color the sound and hence the differences. Besides really hard differences in regards to output impedance and distortion etc. There are HUUUUGE differences in how amps make the same headphone sound.
Apr 19, 2014 at 7:18 PM Post #1,288 of 1,676
Hi everyone.
I use my E07 both with apple products (works great as long as the usb power is set to off and a camera connecting kit is used) and also with a 2 in 1 ASUS T100. On the T100 I have been using the regular USB port.  I am interested in also connecting to the small mini port (USB micro B) on the PC.   Does anybody have any cable recommendations?  It looks like a lot of cables are M to F.
I have also seen concerns that possibly the micro B port on the Asus can be problematic; that it is mainly for charging and special cables are needed to work with regular USB devices (sort of like the camera connecting kit conondrum).
Anybody have experience with this and any pointers?
Thanks.
