BillsonChang007
I normally put it at max gain for the fun of it xP
Just purchased my Andes for use with my iPhone 5. Any need to get accessories or higher quality male to male 3.5mm aux cables that would go nicely with it?
2 to 4 but I am not sure if the note 2 allows itplease double check with others xD
Get a Apple Camera Connection Instead xD
Elsewhere on internet it would be a joke. Not hereDon't know if joke or serious lol, but what are the advantages over using aux?
But I have an iPhone 5Elsewhere on internet it would be a joke. Not here
You use Andes DAC with a CCK on a supported ipad.
I've Checked on the net and yup, that is the best solution
Android phones seems to allow that since jellybean (not every dac but it look like that the Fiio e7 allow it)
There is a condition: You have to use an OTG cable.
Im trying to find an otg cable Micro usb MALE to Mini usb MALE for europe with less than 50cm if someone find that can you link ?
Second question: I have a Creative Titanium HD as sound card for my PC
I heard that the DAC of the titanium hd > Dac of the fiio e7
But what about the AMP side ?
Should i use a RCA cable
http://www.monoprice.com/Product?c_id=102&cp_id=10218&cs_id=1021815&p_id=5598&seq=1&format=2&ref=cj
And i link my titanium (rca side) to the fiio e7 (jack INPUT) to use the DAC of the titanium and the AMP of the fiio e7 ?
or there is better solutions ?
EDIT: instead of spamming this thread, I decided to create my own threads with every question in it
http://www.head-fi.org/t/704910/pretty-new-in-audiophile-world-i-got-fidelio-x1-fiio-e6-titanium-hd-but-how-to-connect-them-properly
So back to the original question what are we looking at with +6dB gain in mW at 32 ohms?
Fun of it is probably, even if that, the only reason to set the gain as e07k begins to sound crispy like a cheap DAP on max. Unfortunately I have to set up +6dB gain for my Q701 sometimes and hence would love to know the physics behind it.
So my E07K that I ordered was on back order. I decided to just cancel it and am wondering if going up from a E07K to an E17 is worth the money. Thoughts?
