FiiO E07K ANDES Review and Help Thread
Sep 5, 2013 at 3:31 PM Post #947 of 1,676
Just to inform you guys that FiiO E07k works fine with Minix Neo X7 android mini PC through USB. And without root too.
EDIT: just to be precise, I didn't connect X7 directly to E07k's USB port but into my E09k to which E07k was docked.
Sent from my NEO-X7-216A using Tapatalk 4
Sep 5, 2013 at 3:57 PM Post #948 of 1,676
Thanks for the info!
I reported it at the following thread:
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/3030#post_9776265
There is a question:
"I wonder if Android mini PC can have UARP installed..."
Could you please test the USB Audio Recorder PRO app, available on Google Play store, with your Minix Neo X7 and your FiiO E07K?
There is a free trial version.
https://play.google.com/store/apps/details?id=com.extreamsd.usbaudiorecorderpro
USB Audio Recorder PRO is currently my preferred music player because it can output a very natural sound. I have also Neutron and Poweramp music players.
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2475#post_9511388
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1185#post_8989408
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/2475#post_9513867
Sep 5, 2013 at 6:48 PM Post #949 of 1,676
I downloaded and installed USB Audio Recorder Pro Trial and tried it with Minix Neo X7 and FiiO E07k.
First try was disaster: the X7 crash & froze. I had to eventually reflash the ROM.
The second try was great success: I can inform you that UARP works with E07k. I tried both mini-USB OTG cable on mini-USB port and normal USB cable on regular port. Both ways worked equally good. I played some FLAC files as long as trial let me.
Oh, and UARP worked with my unrooted (older model) Nexus 7 and E07k through mini-USB OTG cable.
Sent from my Nexus 4 using Tapatalk 4
Sep 5, 2013 at 6:51 PM Post #950 of 1,676
Dual post, my bad. Ignore this :)
Sep 6, 2013 at 2:39 AM Post #952 of 1,676
Damn, thats harsh. I think you could have suggested a headphone upgrade, but with a better choice of words.
What he said! Anyway, I got the Andes, will receive it tomorrow. I will test it out with HD 438s, if all is good will continue using it otherwise I will look for a better pair of headphones. Recommendations are welcome. Budget is ~ $120 - $ 180
Sep 6, 2013 at 2:07 PM Post #954 of 1,676
hi..I HAVE A QUESTION..I SEEN A PICTURE OF THE FIIO ANDES ATTACH TO A RADIO OR MP3 PLAYER. IN SOMEBODYS HAND..IS IN THE FIIO WEBSIDE.. WHEN U LOOK FOR THE FIIO ANDES U SEE A PICTURE OF SOMEBODYS HAND HOLDING THE FIIO ANDES ATTACH TO A PLAYER OR RADIO.. IM INTERESTED IN THE PM3 PLAYER  . CAN ANYBODY TELL ME WHAT KIND OF PLAYER IS IT.. THE ONE ATTACH TO THE FIIO ANDES.. I DONT recognize IT.... cAN SOMBODY RECOGNIZE IT... THANK U..
Sep 6, 2013 at 2:11 PM Post #955 of 1,676
hey, thanks for the reco, but the Q701 is $260 which is way over my budget and the sextetts is not available in India. Also, I read that Q701s leak sound, I use my headphones extensively in office, so something which does not leak sound would be great. And I cannot exceed $180. thanks again.
Sep 6, 2013 at 2:50 PM Post #956 of 1,676
IT WOULD BE REALLY HELPFUL TO POST THE PICTURE. I THINK YOU ARE TALKING ABOUT THE SONY RECORDING DAP THAT JAMES FEATURED IN A FIIO PIC STRAPPED TO ONE OF HIS AMPS.
Try out Beyerdynamic and Audio Technica then :) maybe dt beyer series
Sep 6, 2013 at 5:42 PM Post #960 of 1,676
bowei006, love your CAPS replies.... Haaa..
^ +1
You can go used. That's how I got mine. Check K601 they are pretty good as well.
