emilsoft
- Dec 5, 2014
@FiiO I love the BTR7 and the app, and thank you so much for working on a PEQ - the BTR7 has the chops to dethrone the Qudelix and is on a righteous path. Please continue your efforts and work on refining the software and adding new features in the future - if you retain the DSP platform and just improve the hardware every year-two, I will be happy to stay faithful - don't do what you did with the Fiio m11 Pro - forgotten after a year.. do what Qudelix is doing and you'll be golden with your superior hardware power.
Some key bugs/feedback I noted:
FEATURE: As mentioned few times, really need more than one custom eq preset for user: at least 5, if not 10 is needed - this thing should be one of key priorities as the power of PEQ demands more flexibility.
BUG: IOS keyboard when editing PEQ values - keyboard doesn't have MINUS sign, so impossible to enter negative db - workaround is to copy past minus sign from outside of app, or to first edit a minus value on the graphical eq and then convert that to PEQ.
BUG/FEATURE: No lowpass/highpass for PEQ - fairly important please especially when working with Oratory configs
BUG: BTR7 codec screen doesn't update if say first connects to LDAC 96khz, and user then changes that to LDAC 44khz on Android device - BTR7 screen says it's still 96khz which is incorrect (validated it's 44khz on device developer settings).. Seems it just detects the initial codec sample rate and doesn't update until new connection/codec is applied.
COOL feature: allow for a setting to have always on display on the BTR7, and to display a funky spectrum analyzer - like RME ADI DAC - that would be so sweet; we all know that looking at a spectrum analyzer whilst listening results in a higher fidelity experience, the music simply sounds better ;(
i get that it might impact battery life a little more but it's down to the user if they want to enable so that should be OK
