Hal Rockwell
Weird. Worked for me.
Do you hear a click in the headphones when you go through the EQ presets?
It is a device-stored EQ (as you previously understood) otherwise a firmware update would not have been needed.
Thank you for your encouragement and sharing. The added EQ function is the EQ adjustment of BTR3, which is independent of FiiO Music APP.Says it in the announce post.
"d. New feature EQ only works with the latest version FiiO Music app"
However, only the latest version of FiiO Music APP can call the EQ function of BTR3.
We will continue to work on the EQ function under LDAC coding.
No hence my post above.FiiO states the minimum IOS version is 1.3.9 but I only see 1.3.8 available. I've deleted the app, downloaded it again, and still its 1.3.8. And in the app, under "Check for update" it states it's "The latest version".
Is the IOS app not yet released?
Am i correct in assuming that you can only listen to audio over the HWA standard if played via the Fiio app and not any other source?
