voon
- May 13, 2009
Argh sorry ... my brain autocorrected whatever into LDAC... silly me :/
You can only use HWA with the Fiio Music app (except for Huawei phones which have HWA built-in). You can find HWA in the Fiio Music app settings.Thanks, LDAC works perfectly fine on mine too, I was having problems with LHDC (HWA). These are different competing codecs. LDAC is by Sony, LHDC is by Huawei. Both support playback at ~900kbps.
Well, I can't use it at all with Galaxy S9. When I turn it on in Fiio Music app, BTR3 stutters, stops and goes into standby mode. But S9 does not really have to support LHDC so go figure...You can only use HWA with the Fiio Music app (except for Huawei phones which have HWA built-in). You can find HWA in the Fiio Music app settings.
I do listen to DSD & FLAC on my phone, and I'm not sure whether it's psychoacoustics or not, but I do hear differences between AptX & LDAC. Also listenning to music I do not mind the latency, and really it's not that bad with LDAC.If you not listen Hi-Res files you don't need this super high bitrate codecs, even SBC is enough, only drain more battery for antything.
What else SBC and AptX have identical sound quality, even mesaurements agree this, I also do not hear any differences, only better is lower latency in AptX.
https://www.rtings.com/headphones/learn/sbc-aptx-which-bluetooth-codec-is-the-best
Dear friend,Anyone having a problem with the new update? Right after updating the app and firmware i can access the menu Setting-> Fiio BTR3, but after a while (i switch back and forth between Spotify & fiio music app) the menu Setting -> Fiio BTR3 is disappeared from Fiio Music app.
Dear friend,I Spoke a bit too soon. The settings that are changed within the FiiO app, they don't stick. So every time I connect to the device again, I have to go back into the BTR3 settings and change stuff again. @FiiO Is it not possible to save the settings within the device and have them stay when connecting to different devices etc?
Dear friend,I have the same problem after the update. At first the menu didn't appear at all. After reinstalling Fiio Music the menu appeared on the first run. The second time I opened the app it was gone again.
The other issues are worse though. Using Fiio Music the BTR3 stutters. It seems the unit constantly switch the codec it uses: the logo changes color. On any other apps the volume is whisper quiet.
This is using the 1.0 firmware and Fiio Music 1.0.4 on a phone running Android 7.1.1
Dear friend,
Did you turn on the HWA option in the FiiO Music?
Please try to turn it off and reset the BTR3 to see if it helps?
Best regards
Dear friend,
Please try to exit the FiiO music from settings of the FiiO music then enter again for check? Or please try to reset the BTR3 and reconnect?
Best regards
Hi just got my BTR3 and I like it but thought it would go a lot louder tbh . Also when I press the volume up button the music fades out then back in again . Is this normal ?
