psikey
- Jul 15, 2008
Was back in thread but may have been a black Friday weekend only code.
Yeah, I tried both the codes from back there, but both were dead.Was back in thread but may have been a black Friday weekend only code.
This 12% one still works 150AMP419 (<< think that's only for over £150 spend) normal 10% one then.Yeah, I tried both the codes from back there, but both were dead.
Thanks anyway.
Hello i have Hiby w5 which also has es9218p dual dac which outputs 80mw+80mw @32ohm on 3.5mm ..... i was wondering if fiio btr5 also outputs same 80mw+80mw (double) or just 80mw (single) because in the btr5 official specs here https://www.fiio.com/btr5_parameters it says only 80mw ....
Does the btr5 provide line out capabilities? I would like to use it as a wireless DAC to another amplifier when i am home.
How would i i connect this to a pc and use the low latency mode?
And does anyone have pictures if the inside of this device? I would like to mod it to fit onto my fidelio x1
Anybody know what the filters do?
I'm seeing APOD 1, APOD 2, HYBR F, BRICK, FAST, SLOW, MINI, and MINI S.
The quick-start guide only talks about slow, fast, and minimum phase roll-off. Can't make out what the others do.
