Fiio amps?
Aug 3, 2008 at 11:59 PM Post #271 of 877
Yeah you could RMAA it until you get a flat curve, but it'd still create distortion by applying two levels of equalisation...
Aug 4, 2008 at 12:08 AM Post #272 of 877
Pre-processing with an EQ in the DSP stack before compression for player?
Any frequency graphs for the E3 out there?
Aug 4, 2008 at 12:54 AM Post #276 of 877
Anyway, best setup so far: Cowon T2->100-ohm impedance adapter->FiiO E3->VSonic R-02 Pro. In that order. +100 ohm between the player and the amp turn the R-02 Pro into bass monsters (which is a complete reversal of their original sonic balance - delicate bass, wide-open midrange/treble).
Also the mini-mini cable is rather crummy, a home-baked twisted pair interconnect does magic compared to the original.
Aug 4, 2008 at 1:07 AM Post #277 of 877
Yeah, anyway, consdeirng the Anythingbutipod Freq. graph, tweaked the EQ so the second band so it's at 500 Hz set to 0 so it's -2,0,0,2,5.
Basically near flat but a bit more bright at the lower treble (+ to counter the darkening of the treble by the Fiio).
Mainly got Vorbis -q8 files on my D2, which is 99.5% transparent to lossless to my ears.
Aug 4, 2008 at 4:50 AM Post #278 of 877
How woudl the VSonic R-02 Pro sound without the 100 ohm adaptor? I'm thinking about buying the fiio to add to my Fuze and VSonic R-02 Pro.
Aug 4, 2008 at 8:17 PM Post #279 of 877
Got me RE2's back from replacement today. Fang = legend, I even lost one of the large biflanges but he still replaced that with a new set. Big big thumbs up to Head-Direct. Will tes tout the Fiio with the RE2's today and I'll tweak the EQ to counter for the lack of bass with the RE2's by setting it to: 0,0,0,2,5. (might bump it up if I feel it still lacks bass). We'll see how it senergises.
Will test it out on a flat EQ as well.
Aug 4, 2008 at 8:25 PM Post #280 of 877
For $8,50 it's a no-brainer
Seriously.
Aug 4, 2008 at 9:44 PM Post #281 of 877
They "cancel out" each other's tonal leanings. The R-02 frequency response has treble and midrange elevated over bass, the FiiO E3 boosts everything below 500 Hz, so even though the sound isn't that even (obviously coloured), R-02 do get a nice natural bass boost from the FiiO amp. Only snag is, they do lose some of the high-frequency super-detail. Overall they get more bass, more punchiness, but it's not solid bass bloom/boost and added stability as with the +100-ohm adapter. The adapter only takes a miniplug, a minijack, and three 100-ohm resistors. All available for pennies in an electronic store. Soldering is optional, duct tape and plastiline can be used to isolate connections, and resistors can be tied onto jack/plug contacts.
Aug 5, 2008 at 12:36 PM Post #282 of 877
Oh Snap!
iPhone > FiiO > Shure E4C actually sounds warm and fun now!
and that combo with the HD25-1.. Bass Galore!
Aug 5, 2008 at 3:38 PM Post #284 of 877
Tight bass galore
