snellemin
- Mar 6, 2015
How did you level match the volume? Even small volume differences can shift our perception significantly.Bought an AM3D from a Headfi member. I really like what I hear, with my planar's and IEM's. I hot swapped back and forth between the AM3B and AM3D, which took less then 10 seconds. The sound difference is immediately noticeable.
I swapped back and forth. The effect on my wallet was immediately noticeable
Does anyone know the output impedance on the AM3d? Having trouble finding it myself; thanks in advance.
And just got the text from DHL Tuesday is the estimated delivery day; Wow. Hong Kong to New York in less than a week thank you Fiio.
That sounds about right. I had read the specs early on somewhere but I can't remember exactly where.I know FiiO wrote it somewhere but can't remember where. I think (but not 100 % sure) that 4.4 is less than 1,5 ohm and SE less than that. I 100% sure its less than AM3b. AM3b is 3 ohm in 4.4, a bit too high!
Does anybody know the output impedance on the 4.4mm? I tried to find the info on the AM3C but couldn't.
Hopefully less than the 3 ohms on the AM3B for use with Andromedas.
Dear friend,
output impedance <1.5Ω
Best regards
Too bad. Headphonebar in Vancouver Canada has stock, that is where I purchased mine. For $10 shipping I received it in three days. It was $199 Canadian, so US would have been significantly less. Nice people at Headphonebar.Does anyone know the output impedance on the AM3d? Having trouble finding it myself; thanks in advance.
I like the sound of that.All of my IEMs sound better with the AM3D. This is a very good amplifier. I wonder if some may have had overblown expectations when they gave it their first listen. It settles in very well.
