dbdynsty25
- Aug 25, 2010
I used this combo for a few weeks and love everything about it. You'll be extremely happy with it.
Hello JimmyTryhard,
I have an X5mkII, I will have a pair of A83's on friday. I will let you know how they sound.
Update and major shout out to Michael Lin. He and Fidue have been perfect, accepting my defective (channel cut out) unit in return for a replacement I just received. Still testing it out but no channel imbalance noted to date and I am remembering just how wonderful this IEM sounds.
Kudos to Fidue and Michael. While the frequent reports of channel cutout are noted, their communication and customer support have been stellar and the A83 remains a very special in-ear.
Don't worry , contact Mr. Michael Lin: michael@fidue.com. Had similar problem, and solved.
I've had my A83's about 10 months, and last several weeks the right channel volume is very low and muted. I cleaned connectors, gently moved (centered) the earpiece pin as some suggested, tried a Shure cable instead of stock --> No improvement! Worse still, I am remiss in that I can't locate my receipt nor recall which seller I purchased from to initiate a return / repair for what I suspect is a dead driver issue. Obviously, the lack of receipt /purchase info. is on me, no excuse....I think it was an Amazon seller but there are many.
So self-flagellation aside, any suggestions? Other fixes. Contact Fidue and beg assistance (without proof of purchase date I can't really expect warranty service but they may offer a repair at reasonable cost.)
Thanks for letting me vent and for any ideas to correct the right channel issue.
I believe I have version 2 (locking tab with chin slider) and I have the same issue as you, where the connection was loose. I did cut off the locking tabs, but wiggling the A83 doesn't cause the cut outs. I've been using a Shure cable for over four months now and no issues other than the need to cleaning the mmcx connectors once in a while (which is a long time). This is for the right side, by the way, the left is completely fine.
A long time ago when you mentioned your problem with the version 2, I originally assumed it was a cable issue, but then I believe you tested it by switching the cables and one side just died. Is the cutting out just specific to one side?
Regarding tips, I use Complys and Sony hybrid isolation tips for isolation, but I use the JVC Spiral Dots since I don't use the A83s in loud environments anymore (they are also comfortable).
Oh, when I said 'my unit came in' I meant I received the X5II already.
So far, I've really been enjoying it
The X5II solves all of my problems from my DX50, and it also sounds noticeably better! With the A83's, I find there is for some reason less harsh treble on my X5II than my DX50 and a noticeably more 'refined' sound. It's not something I can put well into words exactly, but in conclusion, it brings new life into my music experience.
Currently listening to as I type:
Clocks Go Forward by James Bay
The guitars... :O mesmerizing...
I am enjoying my new A83's, however I am experiencing severe driver flex in the right IEM.
I do the same thing that H20Fidelity does when putting in my IEMs. This is not making a difference.
Does anyone have any suggestions on how to dress this (besides returning them).
I have already parted ways with my UE-900(s) and returning them would leave my without any headphones, which would be very sad
Comply Sports Tips (S400). Porous foam basically allows them to breathe a little. Should eliminate all driver flex.
Sadly I have discovered that comply tips irritate my ears, My ears are still itching after taking the tips out half an hour ago.
I have emailed the retailer about this, Their response was rather flippant that driver flex is normal for these iems and that I should use comply tips as well.
They do not wish to take responsibility for this problem.
I am really loving these iems, but this is really frustrating.
