@H20Fidelity great write up. Confirmed to me A73 is closer to my liking. Any chance you can do quick compare vs delta on gunmetal ?
I love the ASG sound too. Have you tried ASG plus ?
@nekromantik that's a shame.
Did you cut a stem from another pair of tips and place that under the Meelec ?
You could also try another mod.
Put a small sized tip backwards onto the iem. I.e first slide the ear side so that stem is pointing out.
Than fit Meelec over this stem the right way.
Get the Meelec flange to go over the smaller tip.
This will make a firmer fit. Does change the sound compared to using the Meelec alone. Worth a shot.
Worst case if they still no good to you maybe you can pass onto Djscope, Hisoundfi or h20fidelity
@xoriac
Don't give up so soon. Try wide bore tips such as the Philips one that H20fidelity pictured earlier.
