Coming back to the topic of possible DAC pairings of OOR I am trying to push myself to wait for the Ferrum DAC/streamer to finish and be rolled out.
Nevertheless I have started creating a list of possible DAC/streamers that might fit OOR/Hyosos in terms of size for stacking them up (remember my small footprint requirements) and listed the DAC / preamp output voltage specs.
I've listed only the XLR voltages as I recommend using OOR balanced at least for Susvara / TC.
Personally I'd call anything > 4V acceptable, anything > 4,8V ideal if you want to have more headroom for Susvara / TC + opt to apply additional software equalising requiring additional volume again.
I haven't listened to any of these, so don't call this a list of good synergy DACs, just as a starting point for my own investigations.
Ferrum OOR measurements: 8.6 x 8.1 x 2.0 inch / 21.7 x 20.6 x 5 cm
- Mytek Brooklyn Bridge: 20,6 x 4,4 x 21,8 cm (should be the closest to the Ferrum stack size)
XLR: 9,75V RMS @ 0 dBFS
- T&A DAC 8 DSD: 9,0 x 27 x 27 cm
XLR: 5,0 Veff / 22 Ohm
- Denafrips ARES II: 21,5 x 23 x 4,5 cm
XLR: 4.0Vrms, 1250 Ω
- M2Tech Young Mk IV DAC
XLR: 5Vrms or 10Vrms
- Chord Hugo TT2: 23.5 x 5.2 x 23.8cm
Output Hi gain (Ph/XLR) 8.5V / 17V
Output Lo gain (Ph/XLR) 3V / 6V
Output DAC (Ph/XLR) 2.5V / 5V
In terms of my desire for trying out pairings sound wise this list would be bigger but unfortunately I cannot fit some rack sized equipment comfortably on my limited desk.
Otherwise I'd love to try the likes of Holo Audio May / Spring 3 KTE / ROCKNA Wavelight, etc.
