Paul Noir Culte
Has anyone tried the HYPSOS power supply with the Hugo TT2?
Hi bneiderman, I happen to encounter the exact same issue. I would be happy to know how things progressed for you. Did the problem disappear, did you learn to live with it, or did you finally return the unit on guarantee ?So I was listening to the Ferrum stack last night and had my Empire Ears EVO plugged into the balanced XLR port using an adapter. I noticed that if I changed the volume quickly while nothing was playing I heard a static type noise that was there only while the volume knob was moving but disappeared as soon as I stopped. This obviously was way more evident at the high gain setting. I then tried my ZMF Atrium using the single ended input and noticed the same thing. There was also slight noise floor with the EVO that I don't have with my Topping A90 either. I guess not as black. Either way I want to know if anyone else hears this static noise while changing the volume. I would appreciate any help. Thanks guys!
