FooFighter
Thx for that!if you want to know the actual numbers, just from my memory, it might be wrong but wont be too far off
Mytek 888: 6W into 16 ohms
Benchmark HPA4: 6W into 16 ohms
GSX mk2: 6W into 32 ohm
Liquid Gold: 9 or 10W into 50 ohm
iFi pro iCan: 14W into 16 ohms
Ragnarok: 12 or 15(?)W into 50ohm
Flux FA-10: 16W into 32 ohms,
Flux VOLOT should have even more power but IDK
Dark Star(undisclosed, but I am pretty sure it is more than the 8W OOR)
Custom Dynahi/CFA3: can have more power than everything above depending on your build
note that the GSX, Dynahi & CFA are pure Class A power
Flux claims class A but I am not certain, it doesn't get as warm as any other Class A I know of. therefore I doubt given its power.
Ragnarok and Liquid Gold is partially Class A, change to Class AB on high power.
All others pretty sure does not run Class A.
it is just for your information, I am not going to debate if Class A power is superior or anything. I am not knowledgeable enough to discuss about this anyway. But "Class A" seems to be a thing some people care about.
Looking at the specs pretty much all the amps but last few are having less juice than OOR?
