I will try this tomorrow.KLEI/ETI. The small pin point for the return signal among otherwise plastic bits may not connect properly to a RCA socket, and that may be the reason for hum. Make sure that the fit is tight and then try turning that RCA plug clockwise in its socket.
Great to hear. I‘ll play with this a bit more to see if it is nevertheless a bad KT88The missing pin on the Kt 88 is normal - it has to be.
The pin assignment of the tube specifies this.
Now that I am using only good KT88 as power tubes, along with my other actions, I have no humAnd if you could reduce the hum so far that you don't hear it in the music anymore but only when changing tracks, I would say you did a lot for it and got it reduced to a minimum.
So you could also live with it.
I am now testing 2 Nordost Norse Heimdall 2 power cables. Although I had solved the problem with my DIY power cables, I might keep them to be on the safe side.The only thing you could consider is to choose a cable that is EMI/RFI protected if it is not.
In general, in my experience, cables that are EMI/RFI protected cause far fewer problems in the entire chain than cables that are not protected.
At the moment I happy with having no hum. Let‘s see if it stays this way.
Thanks for all your help
