Melting735
Thanks a lot for your words and advice. I think the dealer is making an arrangement for repairing.Hello,
I don't know what the buying conditions are like in your country.
But the fact is you have 3 years warranty on the purchase of the device.
There are then only 3 possibilities,
The dealer replaces it and takes care of the repair himself. And gives you a new one.
The dealer takes the device and sends it to Poland for repair at his own expense.
The dealer repairs the appliance himself if he has the means to do so.
If it is a big problem for you, I would ask Feliks again what you can/should do. Maybe Feliks is kind enough to send you a label since it is a new unit so that you can send it directly to Poland to have it repaired.
That would be the better way, because Feliks can act more directly.
Feliks may even send you a new unit when the old one arrives.
The other thing is that since you just bought it, you should be able to cancel the purchase. Even if you have a 30-day right of return, the dealer has to take it back.
If he's that stupid, it would have been the last time for me, to be honest.
It sounds like you have already changed the fuse several times.
Could it be a ground fault or a defect in the transformer?
Has the fuse blown every time or has it only happened once?
The fact that it won't switch on now is probably because you have overloaded something.
Like changing the fuse frequently if it has blown every time.
There is often a reason why the fuse blows, and the most common cause is usually a short circuit or overvoltage.
If you can rule it out in your house or flat that it is not coming from your socket, then the appliance has something wrong with it.
I'm still keeping my fingers crossed for you.
Try to talk to both sides - the dealer and Feliks - and then decide for yourself which you prefer.
Of course, it would be stupid of the dealer if he still has an Euforia in stock and doesn't exchange it.
As a gesture of goodwill and anger that you had, and above all, you would actually want to enter the shop again if the service was right.
It is not fuse any more because I tried a few new fuse. No luck at all. Any thing other than fuse will be beyond my diagnose ability. I will leave it to their techs.
I don't like them to repair it because it will take long time and leave me no amp to use, and who knows what those techs will do to the units. However, I don't have a choice now. I will definitely contact Feliks if the dealer charge me shipping or they can't do it.
Ya, finger cross, hopefully it will be a good repair.
