Wow thanks so much, that’s exactly what I’m after! and cheers for including the roles of the pins, this will give me chance to ponder how it works and check my adapters. Very brave of you to go all in!
So I gather the kt family are tried and tested for many many hours? It’s not going to do any damage to my amp right? Just wondering what FA are worried about.
Hi H.
Yes...I and a good few others have used the KT etc family quite extensively (in both Euforia and Elise), with no sign of ill effects to the amp. On the contrary, with the amps thereby also running much cooler than with stock configuration, I personally feel that can only benefit the longevity of these amps lol .
And FA, as with all amp makers, are obliged to warrant only the tubes originally configured for. It just turns out that by some minor miracle, their circuits have proved able to (safely, as we have discovered) accommodate many other tubes also (with adapters)...viz the C3g; FDD 20 (with external heater supply); ECC31/6N7; NR73; EL3N; EL11/12/32/38/39 and lastly the GU50 (again with external heater supply)....amazing!!
As mentioned by @ThanatosVI , always check that the total tube heater draw doesn't exceed 6.5A by very much, with such figures as :
6N13S/6AS7G.....2.5A
KT66.......................1.25A
KT77.......................1.4A
KT88.......................1.6A
6SN7......................0.6A
HAPPY LISTENING!
Hi G.I am interested in this as well as a new owner of the FA Euforia.
To use the KT88 as a quad do I just need an adapter like this: Adapter, and some KT88 tubes to roll in?
I would not want to shorten the life span of this amp by overdoing it.
Yes indeed...either those adapters from xulingmrs, or those from member Deyan, in Bulgaria. The latter are more expensive, black and use wire instead of PCBs. On the whole, folks have been happy with either. Don't know how shipping times differ however...especially to the USA. And a good few folks have used 4x KTs (and more, with external heater supply!) with no untoward effects.
Good hunting and happy listening to you also....CJ
