Arcayne
Haha, I feel you. I'm still very much a noob with the technical side of tube-related things, but learning bit by bit as I go.Tube rolling is trickier than I thought, how am I supposed to know which combination of tubes are safe?
To be absolutely certain that you're safe, you just have to stick to the standard supported tube families, as listed in the user manual. Using tubes that aren't supported by default through the use of adapters is not encouraged nor supported by Feliks Audio, so if anything goes wrong, the cost to repair your amp will almost certainly have to come at your own expense.
As I understood it, the Euforia can provide a maximum of 7A across all 4 tube sockets. So when experimenting outside of the "comfort zone", you have to look at the data sheets of the tubes you plan to use (example: GL KT88 datasheet) to find out how much current each tube draws, defined as Ih under the Heater specs. In this case, approx 1.6A per tube, so let's assume 1.7A to be safe. Add up the Ih of all 4 tubes (4 * 1.7 = 6.8A), and that's how much current the tubes will be drawing from the amp. This should always be less than the maximum amount your amp accepts (7A for the Euforia), otherwise you need an external power source for it to work.
So you can be relatively assured that running 4x GL KT88 isn't a problem for the amp.
P.S. Correct me if I'm wrong, I'm not an expert either.
