gimmeheadroom
Yeah the HD 600 scales extremely well.
Drop (formerly Massdrop) still has the HD650 for $200.With HD650s in hand and stock powers in position (I had an EL39 fail on me), I must second this! First set-up I’ve had where I felt no need to EQ.
To the Tung Sol 5998 owners, how is the amp temperature when running these as powers? Compared to stock, which can get the amp quite warm during long sessions, ELs run very cool.
It's a while since I last had my 5998 powers in the amp but I'm fairly certain they run a lot cooler than 6080's but not so cool as EL's. Certainly not too hot for these amps and also a very good power tube in both Elise and Euforia.To the Tung Sol 5998 owners, how is the amp temperature when running these as powers? Compared to stock, which can get the amp quite warm during long sessions, ELs run very cool.
6080'S always ran the hottest on my amp. The 5998's ran it warm but not hot. Now running the Gold Lion KT77 as drivers and Gold Lion KT88's in power position and am extremely pleased with the results. I started with the quad of KT 88's and went to 7581A's as drivers, which had a great sound as well. Now running the KT77's as drivers, so far this is the best I have heard from my amp. Quad of KT66's were also quite good. Using them as Pre amp out really warms up the Anthem amp. Also uses less volume than the 7581A's. Not quite as bright. Bass is a little stronger also.
gimmeheadroom which tubes?
Thanks, it is really great to read tube rolling threads as an efficient way to save money
I can't order from outside the EU but aren't the Gold Lions made in Europe maybe even Czech Republic? I should be able to find a source...
They do stock the GL KT77as well at £39 per tube.They are usually available from Hot Rox UK at approx £47 per tube thats -KT66/88 they will stock KT77's I'm sure.
