Dobrescu George
Reviewer: AudiophileHeaven
I posted my in-depth analysis video about Feliks Euforia!!
There's a full written review incoming as well
Hi h1,
I still have my Euforia. If I wanted to sample the latest developments in improving the sound of it, what should I get?
1) A pair of KT66 as drivers and a pair of KT88 as powers
2) Quad of KT88
3) One KT66 and one KT88 as drivers and a pair of KT88 as powers
Which brands would you recommend for the KT66 and KT88? All Gold Lion reissue?
Four adapters - I assume that they all are the same? Can't seem to find the adapters listed.
CJ, those gold adapters are perfect size looks like they were made for them!
Hi @hypnos1. Glad you're enjoying the KT88 quad incrementally more than other tube combinations. Can you elaborate on the difference in gain (amplification factor) between the GL KT66 versus KT88? I've been unable to find this specification in any of the related tube data sheets. Thank you, good sir.The lower gain from the 88 compared to the 66 means turning up the vol knob a bit more, but brings this wonderful benefit. And even with the vol knob turned up quite high, I get no distortion whatsoever.
Understood, thank you @hypnos1. I should receive a pair each of GL KT66 and KT88 in the next several days. I have adapters by Deyan ready to go, and look forward to listening. I enjoyed the TS 7581A's, am currently running NOS TS 7236 powers w/new production TS 6SN7GTB drivers which is quite pleasing as well. Seems there are an abundance of riches / good choices with our amps. I may eventually try a quad of KT88's as well but trying not to rush the journey nor break the bank!Hi LW.
Yo, this quartet of GL KT88s is proving to be the crowning glory of years of messing around with countless different tubes that my poor old amps have had to endure lol!! And amazingly, they still work flawlessly lol! As with @connieflyer , my current setup is performing so well that I have no desire whatsoever to even look at other amps any more! And besides, who else makes a headphone amp - or any other for that matter - that uses the KT88 as drivers to the same as powers? I personally wouldn't now even consider trying any other driver for the 88 powers...they meld together far better than I ever thought/hoped for.
As for the 66 vs 88 gain issue, I actually only came across this in one of the myriad posts I've scoured from users in other (power) amps. And then I realized this would account for the much lower hum thru my HD650s when substituting a 66 driver with an 88, and complete absence with 2x 88 drivers (replicating the experience I had with my mesh plate EL11s compared to the standard tubes - higher gain obviously via the mesh plates!). Plus, the need for slightly higher volume knob setting also confirms this.
Understood, thank you @hypnos1. I should receive a pair each of GL KT66 and KT88 in the next several days, have adapters by Deyan, and look forward to listening. I enjoyed the TS 7581A's, am currently running NOS TS 7236 w/new production TS 6SN7 which is quite pleasing as well. Seems there are an abundance of riches / good choices with our amps. I may eventually try a quad of KT88's as well but trying not to rush the journey nor break the bank!
Hi h1,Hi LW.
As for the 66 vs 88 gain issue, I actually only came across this in one of the myriad posts I've scoured from users in other (power) amps. And then I realised this would account for the much lower hum thru my HD650s when substituting a 66 driver with an 88, and complete absence with 2x 88 drivers (replicating the experience I had with my mesh plate EL11s compared to the standard tubes - higher gain obviously via the mesh plates!). Plus, the need for slightly higher volume knob setting also confirms this.
Hi h1,
Did you come across an actual number for the amplification factor of the KT88 and KT66?
