While I'm not sure on the Grado pairings
Thanks anyway....let's see if anyone else can answer my question
Maybe I ask a stupid question, but regarding these asymetric combos (different types of tubes in L vs R socket), I was expecting that each channel of the HP has associated a power and also a driver tube. When you use such a combination are you obtaining different flavours for each headphone driver or?
Good news from me too on the KT66:
Although for an unknown reason my specific (unmatched) pair of GEC KT66's are not giving clean / balanced sound in a conventional (one-tube-per-socket) setup for me - I am happy to report I am getting first-class sound out of a very unconventional setup. With my custom externally heated multi combo I paired 2x KT66 with 2x EL39 and got world class sound with tone, air, FR, etc. of nearly unrivaled levels. H1 was right on the KT66 + EL39 synergy, and this way the imbalance & distortion were completely gone. After some testing I finally found 2x GEC 6080 to synergize best with the former 4x as a 6x power combo, driven by 2x Valvo EL11 or EL12 Spez. The KT66 in this capacity is the sound of "love", a sound that likely has not been matched, one that I can't do without and that the mere notion of removing it seems like sacrilege.
The above was meant to illustrate the potential of the KT66 in the Euforia; although such multi-tube setup is not endorsed or specifically recommended. A better matched pair or a different brand should do quite nicely as 'conventional' powers on the Euforia. Or even Tung Sol KT66 or perhaps Genalex Gold Lion KT88 which are not too much more expensive than Gold Lion KT66. From my testing these are best suited in the 'powers' seat, as I got somewhat slow dynamics with these as drivers.
Thanks I'm certainly enjoying them, I'd been after a closed back for a while, tried a couple, which I couldn't get on with, anyway, going on what I'd read decided to give the Atticus a try, fortunately I managed to get a used, four month old pair in as new condition, fortunately they're everything I hoped they would be, warmish, with great tone, good, deep, but not boomy bass, and compared to some closed back I've had surprisingly airy, with decent soundstage, and despite they're warmth surprisingly lively too, especially with tube amps. As for those Verite closed, they look, and from what I've read sound to be very impressive, sadly at the mo my budget can't quite reach those but maybe one day in the not too distant future.congrats they look lovely. I Demoed these a while ago straight out the h2 before the euforia arrived in my life and ended up with the elegia, but if it had been the other way around I think having subsequently heard them at car jam via tubes, the decision might have been reversed. Interestingly the verite closeds (look away here, I’m about to be blasphemous) are very well match with solid state amplification supplied by hugo2 and even better out of the tt2. They have such and airy wide/tall/deep stage, so much headroom and a warmish side of neutral tuning that they compensate for the only short comings of the chord DACs while allowing all their clarity, dynamics and focused precision through. This has been some forced learning while my euforia’s been away. Back on topic, my euforia has not left the uk, because audiobarn carried out some more tests under Lukasz guidance and surprise surprise they could recreate the issue and the amp’s performed flawlessly,
Good news the euforia is okay, bad news a mains gremlin has moved into my house, effecting rooms on separate circuits, getting by my bmu and occ power cables. I’ll be collecting it on wednesday and more bad news the anniversary edition should probably be their with a days run in.........
Hi @LoryWiv, my GL KT66 arrive yesterday and so far very impressed, only have 14 hours on them so far, if you like the TS 7236 and 7581A then you should like the KT66, wide, deep soundstage, very detailed, great imaging, separation, and not overly warm, btw, this is using Elise.I've spent the last day burning in the Tung Sol new production 7581A's in my Elise's power position, will share initial thoughts here as this thread has been the focus of 7581A discussion. Early days, but oh my I am impressed.The primary characteristics I note are clarity, linearity and coherence. There is superb balance across the frequencies and more than sufficient speed to keep up with complex musical passages without slurring. Stage height is better than any powers I've tried, including my trusty TS 7236's, with width / depth about the same and instrument placement as good or better. The "note thickness" is just right, whereas with the 7236 things sounded a bit thin at times. Compared to my TS 5998 powers the 7581A's are a little less warm, bringing more detail but not at the expense of a pleasing musicality and euphony.
All of these comparisons are with new production Tung Sol 6SN7GTB drivers and the 7581A's seated in adapters from Deyan.
I may roll in some NOS drivers like Sylvania 6SN7's to get a bit more top end sparkle, I want to hear if they can achieve that without being fatiguing, but the ones I recently ordered had unacceptable noise levels so that will have to wait.
Lastly, I am looking forward to hearing more impressions of the Genalex Gold Lion KT66's, specifically wondering if these magical 7581A's can really be bested, or if the KT66 as powers driven by the 7581A's would be a winning partnership. I don't have EL 38's or 39's, and am not a big fan of anode caps and connectors, so I am considering these simpler pairings and will appreciate any comparative impressions.
Now (really) lastly, thanks to the regulars in this thread for advancing the cause of musical bliss with our versatile Feliks-Audio amps. This is a great community!
Hey I'm a little confused on your above post. Did you mean to say there's a shortcoming of the DAC of the Chord Hugo 2 or Hugo TT? If so, what does it seem to be?congrats they look lovely. I Demoed these a while ago straight out the h2 before the euforia arrived in my life and ended up with the elegia, but if it had been the other way around I think having subsequently heard them at car jam via tubes, the decision might have been reversed. Interestingly the verite closeds (look away here, I’m about to be blasphemous) are very well match with solid state amplification supplied by hugo2 and even better out of the tt2. They have such and airy wide/tall/deep stage, so much headroom and a warmish side of neutral tuning that they compensate for the only short comings of the chord DACs while allowing all their clarity, dynamics and focused precision through. This has been some forced learning while my euforia’s been away. Back on topic, my euforia has not left the uk, because audiobarn carried out some more tests under Lukasz guidance and surprise surprise they could recreate the issue and the amp’s performed flawlessly,
