Hi LW.
There's a world of difference between using
single adapters and
multi ones in an amp not specifically designed for such use. All the 'alternative' tubes I have adapted for years now have been extensively tested, not only by myself but many other users also.... and none more so than the EL family of tubes. And although F-A can't
officially endorse their use, Lukasz has confirmed to me that he isn't now at all
unhappy with them, even though they did find the bench readings 'unusual' lol! And he agreed that they are obviously
safe to use, given how long I especially have used them without anything untoward whatsoever, in either Elise or Euforia....further reinforced by my testing of every single internal component's operating temperature, showing that they ran at
10 deg C (
50 F)
cooler than with stock tubes, and a section immediately below the trafo at
20 deg C (68 F) cooler!!
Therefore, the use of such tubes will not, of itself, cause any warranty-voiding damage. Naturally - as with
any tube - there's always the
slight possibility of it 'blowing'/arcing, but hopefully our amps' protective circuitry should be able to prevent major damage, and cannot be blamed upon it being an 'alternative' tube. With regard to the adapter itself, although the occasional Chinese one has failed (which Mrsx has always happily replaced), I've yet to hear of it causing any damage to the amp. And I would recommend that if ever anyone has the slightest doubt about an adapter's functioning, it is reported to the maker and replaced...assuming all the usual tests have been made to eliminate any other cause first...ie. swapping adapters/tubes; checking the tube's pins are shiny clean; tubes and adapters are seated properly; all cable connections in the system are secure/clean, including the power supply connector!...etc.
And so, in short, so long as one hasn't gone more extreme than this; taken the usual care in using the amp, and with tubes that I myself have proved to be safe, there's no reason why the warranty should be voided, if the worst should happen...they can (usually) soon determine the actual cause of any problem!
So fear not, mes amis!
...CJ
