Hi Johnnysound,
The main reason I became interested in the 6F8G tube is that the Tung Sol variant is supposed to sound the same as the TS 6SN7 black round plate tube which is very highly regarded and unfortunately very expensive. (There is a 12V version, the 12SN7GT BRP as well, but those are also high priced.)
The TS 6F8G comes as flat plate and round plate, but according to UT they sound the same. I found a lot of four 6F8G tubes with one Tung Sol, one Raytheon, one Philco (Sylvania) and an unknown brand Radiocoin. By looking at the pictures it seemed to me that the Radiocoin could be a rebranded TS, and when I received the tubes I confirmed that it was indeed a Tung Sol tube. Both are flat plate tubes.
The sound is unique and the best word I can think of to describe it is "creamy." Wide soundstage, very good detail, even FR and that smooth creamy presentation....
The Raytheon and Philco sound good as well. As always you need to find the right power tubes to pair them with. At the time of pairing I used the Cetron 6336B but was subsequently advised that they could harm my amp (even with external power and all cooling and ventilation precautions) so I stopped using them.
My advice on getting these tubes is to try to find an inexpensive pair (not necessarily TS) and try them out. You also need special adapters which adds to the expense.
There is another tube that is very similar but with higher gain (similar to 6SN7 vs 6SL7) - the 6C8G. Not 100% sure if it is compatible with the Elise/Euforia, but not that expensive. Here is an example:
https://www.ebay.com/itm/6C8G-6F8G-...109220&hash=item4b435fdbef:g:oRwAAOSw-0xYaUv2
I haven't tried it yet but may be a good possibility....
ATM trying another driver tube that also was a predecessor to the 6SN7 - the 6N7. It is a metal tube (I am told that there is a glass envelope inside). Since it does not have any visual appeal it is very inexpensive and you can get a WW2 NOS pair for $10 or less. Testing a Ken-Rad 1944 pair now.
These tubes need special adapters as well - ECC31 to 6SN7.
If you want the TS 6F8G be patient and keep on looking for rebranded ones such as ART and Radiocoin - I paid $84 for the four tubes including shipping.
Good luck!
