Indeed J..@connieflyer has the straight-sided tubes as well as the ST-type - both termed 'CV1052' - but I just love the 'shaped' tubes every time, as you have gathered!, so I've left it to him to be guinea pig with the straights...(and I'll be sick as a parrot if they perform to the same level lol!!
). And it will be interesting to see if my Pinnacle branded EL32s sound the same as my military CV1052...one Pinnacle having a brown base (which I also love in a British tube!), and both looking just as impressive...
Anyway, as you asked - along with
@DecentLevi - I will give an update on how these tubes are sounding, with another 10+ hours on them...even though it's still early days for them!
Well, first of all I must admit they exceed all my expectations - was hoping for 'good', but they go way beyond that...
in my system!...especially with EL12 Spezials as powers...(and DL, yes...I suspect the extra power of the 12s is preferable in that role!).
Last night it appeared I might have to get used to (quite a lot!) heavier bass and mids than I'm used to, with slightly less treble...but this morning they've toned down some (more to my taste, thankfully, and which often happens anyway). However, there is still a bit more in these areas than the EL11, which is no bad thing lol! Bass detail is still very good, with excellent control and 'tightness'.
Treble is
very slightly down, but again has its own benefits - tracks that before could occasionally sound a little harsh at high listening levels are now more 'friendly', but without loss of detail and extension. This was borne out especially with Genesis's 'Duke' album, which has
loads of treble, and can easily become tiring on the ears at higher levels! This also means that amp volume can be turned up, without the ears objecting so much...a good bonus IMHO.
Overall balance is very good, with the slightly more bass and mids reminiscent of the mighty ECC31 and FDD20, but without the high heat that goes with the former lol! It doesn't have the same treble 'sparkle' of the C3g, but as I said, is much better for longer term listening.
Again, like the EL11, the sound is beautifully clean and clear...a little less 'coloured' than the EL3N, and at least on a par with my mesh-plate EL3N
G and Valvo EL11. In fact, at this rate, I suspect I will prefer these even to my rare mesh-plates - the Valvos giving the very slightest hum (in my system) that is unnoticeable while music is playing.
Another reason for this probable preference is that not only will they take even less power than the EL3N/EL11, but also something I only really noticed with Cassandra Wilson's 'Another Country' (HD Tracks 2013 sampler) - ie.
slightly less echo due to the cross-feed implemented in our amps. This results in a tad less 'air', and a little more focus...you can't, by definition, have both lol!! Now that I've got used to the slight difference in sound this gives, I think I prefer a little less 'echo'! But this will also depend on the rest of one's gear/cables etc., of course...
Yet another aspect of the lower power draw/output of these tubes is that there's far less spike/'crack' when switching off the amp with the headphones still attached, which is another bonus. But later models than mine should have reduced spike anyway, and this doesn't really affect me as I always power everything down just from the soft on-and-off balanced mains & filter supply, plus mains regenerator (plenty of protection there also lol!!).
So all in all - as you may have gathered by now! - I am mightily impressed with this CV1052/EL32/VT25...the ST-shaped tube anyway...so far. I just hope I can get cf's adapters finished soon...
But again I must stress...
in my system, and to my ears/preferences!...HAPPY LISTENING!...CJ
