Updated MM version comes with a mesh! Nice
Nice to hear they made this change!
Curiosity took the best of me (as usual). Baby subwoof’ ordered.
Looking forward to putting them against my Z1R, EST50 and E5000.
I don't think that's a good idea. We already have a huge bass shelf with the Mini.
EX800ST needed the tape mod to get the bass up there.
DHL says my Mini will arrive Next Tuesday.
K7 is a good choice with 6 times the power and THX amp stage. I'm thinking about getting one for my desktop computer as well.
Maestros take some power because of all the damping, I'd keep an eye out for a 2 pin, 4.4 mm aftermarket cable as well to get that extra balanced juice!
The plug holes Maestro Mini doesn't have any deep recesses(or any recess at all) or weird notches - so they should fit any 2-pin adapter, but I'm not sure if the design of the Shure's earhooks make any difference to the fit/comfort, esp. with an adapter.Is it possible to change the câble of the Maestro Mini and change it for the Sure TW2S (With the correct adapter) ?
Absolute madmanI've had mine for a couple of months, but find that for me personally I need to EQ to get to the slam and rumble I'm after. Anyone else here EQing more bass in?
yep im also adding 3-4 dbI've had mine for a couple of months, but find that for me personally I need to EQ to get to the slam and rumble I'm after. Anyone else here EQing more bass in?
Nice one!yep im also adding 3-4 db
Yes. it has a grill and I put a silver cable on it. After burn in this thing sounds very coherent and awesome. Initially treble was very spicy, bass wasn't as refined and not very coherent which is why I think if you're not patient, you'll think you wasted $599.You mean the Maestro's Mini design has been updated to include a protection grill?
Nice! which cable did you put on? I'm in the market for a silver cable right now, but I didn't realize that cables could get so expensiveYes. it has a grill and I put a silver cable on it. After burn in this thing sounds very coherent and awesome. Also, if a song doesn't have that BASS! it will not show up, but if a song has that real deep BASS, you'll be caught off guard when that low bass note drops. Love this IEM.
Im using this one https://eliseaudio.com/collections/.../cema-ms-upgrade-cable?variant=42248872067290Nice! which cable did you put on? I'm in the market for a silver cable right now, but I didn't realize that cables could get so expensive
Thanks for the suggestions! I'll have a look into them.THIEAUDIO EST Cable MKII
Sounds really good for only $69. I also have their Oceania Silver, copper, palladium Cable which sounds more holographic @$199
Thieaudio cables are great modular options.THIEAUDIO EST Cable MKII
You can get the same effect using narrow bore tips. I've experimented with all kinds of tips but yeah this bass is insane on the songs that have those deep rumbly notes. Leaves me smiling all the time. X-Mas came early.yep im also adding 3-4 db
