spritzer
Member of the Trade: Mjölnir Audio
- Aug 22, 2002
The gain is 500 I believe or I'm just too fried from reading way too many tube data sheets today.
A small amount of NFB is applied to the sources of the diff pair. However, the NFB is small enough that it does not entirely control the gain of the amp, which is still primarily in hands of the jfets. The values chosen are an average value to bring the average gain down to about 1000. Jfets with high transconductance will cause the amp to have higher gain and vice versa. |
Originally Posted by spritzer /img/forum/go_quote.gif Ahh ok. I blame it on obscure TV tubes messing with my brain... |
Originally Posted by BoilermakerFan /img/forum/go_quote.gif Oooo. I have a box of those and HAM radio tubes in my basement. Send me a PM if you come across some with great potential. |
Originally Posted by sumo-kun /img/forum/go_quote.gif Regarding balanced vs SE, how about if I want say 600V at the output. For SE, that means the volume pot will need to be turned to say position X. But for balanced, the pot will be turned to half of X, or basically the amp will need to amplify half as much? So keeping that in mind, won't distortions etc from the higher gain needed in SE affect sound? Whether you'll be able to hear the difference or not is another matter, I know Just thought I'd throw that on the fire |
Originally Posted by runeight /img/forum/go_quote.gif Yes. I explained this in post a few pages back. The distortion goes up slightly if you drive the same output with SE. |
Originally Posted by wiatrob /img/forum/go_quote.gif Balanced vs. Un - that's another thread isn't it? That said - we did notice a difference with the proto at RMAF. even though there's not supposed to be a gain difference between the two inputs, we heard lower gain on the SE. Larry, did we ever listen to the dif's after we solved the source problem? I think it was only running balanced from my Opus the rest of the show. Sherwood has listened extensively SE, perhaps he could be cajoled into sharing his experience. I can A/B with my DAC Magic, but can't be sure of it's output stage topology differences between SE and Balanced. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif The "dif's" ? |
Originally Posted by jgazal /img/forum/go_quote.gif Wouldn't be better to add a "phase splitter"? |
Originally Posted by wiatrob /img/forum/go_quote.gif That's what we computer geeks call a 'difference' And I think the addition of a phase splitter (while an excellent solution) would be beyond the scope of the requirements for this particular amp. Luckily it's got spectacular price/performance. |
