Isn't this a one-sided view? By saying it's worthy of criticism, you are indirectly saying it's not worthy of praise. lolAnd if a headphone is so sensitive to chain that it sounds like a completely different headphone on another amp, then that itself is an attribute worthy of criticism.
Excerpt from my article:
I never said that you must share the same views as me. However, by dismissing my perspective and findings, you just show how closed-minded you are.YH-5000SE’s sound variability is its philosophy, it’s at the core of what makes it so special. To assume otherwise is to misunderstand the essence of expression. The same applies to its unique tuning. I see it as an instrument in the purest sense: you can play it, and sound will come out, but that doesn’t mean you played it. It comes with no manual or instructions on how to play it correctly. [...] The moment you accept its sound variability as an inherent quality is the starting point of understanding this headphone. From that point onward, it’s all about how badly you want to hear it.
And there you have it, literal proof of your closed-mindedness. Just like Kammerat, you are dismissing and rejecting opposing views. Another absolutist claim. Not only that, but you had to resort to an insult and label my observations as employing sophistry. Whereas I can understand and accept both as valid opinions, you cannot accept that YH-5000SE's chain pickiness can be a major advantage.If the YH-5K cannot [sound 'great' on every setup], then that's a weakness, not a strength, no matter what sophistry you employ to justify it.
Ironically, you prove my point. You have 4 headphones and are getting 4 sound profiles out of them, but you can have one Yamaha YH-5000SE and get 𝑥 number of sound profiles, basically allowing you to own multiple headphones. Are you denying that getting multiple sound profiles out of a single headphone is an advantage? Or are you trying to deny that this is possible as a whole (despite multiple people sharing that it is indeed possible)?I have 4 wonderful headphones in my regular rotation. All of them sound great on every chain. Sure, there's still synergy at play here, and they'll sound slightly different on different chains, but their fundamental character remains enjoyable everywhere.
You dug yourself a grave with this one. Let's get the record straight:Also, Kammerat has stated in the other thread that he has a friend who loves the YH-5K; while he doesn't share that friend's view, he has acknowledged it, so don't go around saying that's he's trying to slander the product. He's offering criticism, just like anyone has the ability to do here.
1. My first post in the YH-5000SE with my findings
2. Kammerat suggesting Yamaha made a mistake, and making absolutist claims about its sound by referencing a FR response from ASR.
He said that Yamaha failed at whatever they were aiming for [I'm assuming in terms of tuning], he further reinforced his absolutist claims that the YH-5000SE is peaky, and also assumed that Yamaha is not selling a lot of these.
And here's where it all starts—keep in mind, his post was made after mine, so this is his response to what I had to say about achieving two great improvements when using my iBasso DAPs as sources, and to my claim of getting rid of peaks when using the DX340 DAP—he indirectly dismisses my findings by [indirectly] comparing me to his buddy. His buddy loves Grado and compared the YH-5000SE to Grado. He is indirectly saying that his buddy loves peaks.
3. My short response4. Kammerat confirming his dismissal of my findings
By saying "No chain can remove a large midrange peak unless it uses equalisation", he indirectly tried to invalidate my observations and suggest that I was using EQ to achieve the results. Here he undeniably confirms that he is comparing my findings to his buddy's. Kammerat hates the YH-5000SE for how peaky it sounds in his pairings, but is saying that's exactly what his buddy loves it for = I love it for sounding peaky. Textbook gaslighting.
5. My responseI literally called things for what they are. Everything I said here is true—if you claim otherwise, I'm all ears.
6. Kammerat's reply. Aka Gaslighting Supremus. After this, another member joined him in gaslighting. I stayed silent and responded to all of this in my article.
So, @SolarCetacean, that's not called criticism. He didn't do what you're claiming he did. I am not going to assume whether you intentionally tried to manipulate the narrative—just like Kammerat—but you did fall for his deceptive posts. I will say that putting intentions and words in another man's mouth never goes well.
Those Head-Fi posts aren't going anywhere. You can try to twist words, but the posts are there to serve as proof of what was actually said. The truth is there.
Personal attacks are the last resort of those who’ve run out of arguments. If you’re upset that I won’t stoop to emotionally-driven insults or baseless claims to fit your caricature of me, I’ll gladly wear that as a badge of honor. The same way you're trying to frame me as someone I am not, you are trying to frame the YH-5000SE as something it's not—in the sense that you are saying how it sounds in an absolutists way, instead of simply stating that this is how it sounds through your XYZ pairings... Is that such a big deal for some of you? To admit that your observations and findings are limited?
The only valid thing you said in your post is:
And yes, I've read through your long sound impressions and even though you've found a good combo, there's no guarantee that if I heard the YH-5K on your chain that I'd come to the same conclusion as you. That's just the nature of headphones; two people can sit in the same room and listen to the same headphones on the same chain and come away with different conclusions.
When you’re done cherry-picking and are ready to address any of the points I raised, let me know. I'm always here to have a healthy debate.
