True, the Ether 2’s EQ very, very well.E2's much like HEX v2 sound different depending on position IMO. Too bad so many against EQ, it's needed by both and really improves things.
ETHER 2: Impressions and Discussion
- Thread starter MattTCG
bagwell359
If I heard the E2 at the end of a top notch chain, EQ'd properly 3 years ago I would have named it a top 2 or 3 can. It doesn't get enough respect mostly because of the treble. I know for me its treble is way better for acoustic music than over the top stuff from Beyer, AKG, Grado, or even HFM HEK v1 or Ananda. Along with the E2, Dan Clark's Voce proves he's got a real ear for properly recorded music in good venues.
mboerma
- Jun 24, 2012
I'm late to the party, I know. Just bought the E2's. I have had the original Ethers for 5(?) years now, really since they first came out. I have an issue with the comfort of the Ether 2 headphones. I have a large head, big ears, low on the head (don't try to visualise it ;-p ). The head band is always touching the nitinol things. It hurts my head. I try to push the head band down but that doesn't help for long and it brings my ears in a uncomfortable crunch inside the ear pads. The original Ether's do not have this problem in my case. There are blockers on the nitinol straps and the head band is a non-perforated and thicker one.
What advise do you have? I tried to find it in this thread, but could not find anything beside completely destroying in the nitinol bands.
ra990
Have you tried the other pads? They have bigger ear holes than the stock pads and I found them to alleviate any comfort issues. I think the stock pads probably sound the best, but they are definitely not the most comfortable of the three available ones. I highly recommend the suede/fabric ones for comfort.I'm late to the party, I know. Just bought the E2's. I have had the original Ethers for 5(?) years now, really since they first came out. I have an issue with the comfort of the Ether 2 headphones. I have a large head, big ears, low on the head (don't try to visualise it ;-p ). The head band is always touching the nitinol things. It hurts my head. I try to push the head band down but that doesn't help for long and it brings my ears in a uncomfortable crunch inside the ear pads. The original Ether's do not have this problem in my case. There are blockers on the nitinol straps and the head band is a non-perforated and thicker one.
mboerma
- Jun 24, 2012
Thanks. It is still possible for me to return them so I’ld rather try some other solutions first, if any. I did notice that the pads are not as wide and nice as the ones on the Ether Original. They seem to stay cooler.
Contact info@danclarkaudio.com and explain the fit issue. Sometimes people with large heads benefit from using a different strap from one of the other headphones. If you have wire contact we may be able to assist.
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
mboerma
- Jun 24, 2012
@mrspeakers Thanks. I sent an email and got a reply from Susan. I think you misunderstood me. I will send her some pictures. My head has contact with the wires.
Hi! We understood. We think we have a solution, we'll email you.
mboerma
- Jun 24, 2012
@mrspeakers Thanks and thank Sue (not Susan).Hi! We understood. We think we have a solution, we'll email you.
mboerma
- Jun 24, 2012
@mrspeakers Don't want to push you, but I need to know if this is going to work. I have not heard back from Sue. Otherwise I will have to return them, I'm afraid. Thanks.
Got my set of perforated earpads last night and mounted them this morning. There's no denying the comfort and sound of the suede pads, which I really like. After a short listening session to the Ether 2's with the perforated pads all I can say is this is the sound signature for me. The sound is much more lively and detailed than with suede pads. The perforated pads go a long way to let some of those missing treble frequencies through, which was my biggest gripe with the Ether 2's. Not anymore, the Ether 2's sound absolutely sublime with the perforated pads.
LCMusicLover
Any changes to lower frequencies (other than relative to increased treble)?Got my set of perforated earpads last night and mounted them this morning. There's no denying the comfort and sound of the suede pads, which I really like. After a short listening session to the Ether 2's with the perforated pads all I can say is this is the sound signature for me. The sound is much more lively and detailed than with suede pads. The perforated pads go a long way to let some of those missing treble frequencies through, which was my biggest gripe with the Ether 2's. Not anymore, the Ether 2's sound absolutely sublime with the perforated pads.
Thanks!
Thanks!
The perforated pads increase the relative high and low frequencies so you should also get a little more "bump" from the tonal balance.
Yes, the bass sounds “bigger” as in it has a little more presence. It’s also tighter with a nice thump to it. The overall sound seems more balanced and open now. The Ether 2’s don’t seem to sound restricted. The midrange also benefits because its sounds cleaner.Any changes to lower frequencies (other than relative to increased treble)?
Thanks!
Xcalibur255
- Feb 4, 2008
So to sum up: the perforated pads make the tonal response slightly V-shaped?
Total: 11 (members: 0, guests: 11)
