Hey, new to the E2 discussion here as I will be receiving a pair from another user today. In regards to the output between 8 and 40ohms, is this a reference to the amplifier output impedance, specifically OTL tube amps? I'm under the impression that the majority of headphone amplifers' output impedance is closer to the 0.5-1.0ohm range, with the exception of some (Aune x7s comes to mind at ~10ohm). Is this suggesting the E2 will pair better with my X7s than the THX 789 from an impedance/power standpoint?That's true with the caveat the output impedance of the transformers is reasonably close to that of the load. If the output impedance is much higher than the headphone's impdenance, power transfer can be greatly reduced. E2 is ~22ohm and will work well with outputs between 8 and aroudn 40 ohms, outside that range efficiency may be too compromised to get adequate SPL unless the amp is very powerful. For that reason, hybrid designs can be more reliable.
Hope my question makes sense, I'm a bit newer to everything.
