Law87
- Feb 10, 2014
I am extremely sensitive to any amount of treble harshness. The RME ADI-2 DAC -> SPL Phonitor X combo is super neutral, and the amp is solid state so it interacts with the headphones differently than a tube would.
Even with my extreme sensitivity, it's not noticeable in most songs at all. One good example is Daft Punk - Doin' it Right. With each hit of the snare--particular as the song gets a little less busy in some of the middle parts--I can hear a slight glare. It's a tiny amount of semi-hard brightness makes it mildly unpleasant.
Again, I'm tremendously sensitive to treble. I can't handle much more treble than a modded Sennheiser HD650. My primary IEMs are Future Sonics MG5HX, which are notably tilted a bit dark.
The Audeze LCD 3 are also known for being fairly dark and are somewhat comparable to the Ether 2. I also found those to have a little bit of a swooshy crunch on the same track with the same setup, while something like the ZMF Aeolus does not.
I'm glad I'm not going crazy or my ears not going bad. This is totally different from Dan earlier works
