EagleWings
Both Zeus and Phantom have a hiss on all 3 Sony DAPs: 1A, 1Z and ZX300. But I would say the hiss is very mild. Far from what I have on Hugo 2 or LPG.
After owning the legend x I tired so many tips
Here is my ranking best ones
1- spinfit double flange the red ones- gives best presence of mids with best bass and soundstage and details
2- spinfit double flange the black ones
3- final audio small size- mids sound bit lacking compared to the above
4- comply foam tips- ok nothing more
Worst tips I tried
1- jvc spiral dots - very bad the worst xperience
2- mandarin tips
3- regular spinfit
Tips that don’t work as they do not stay on the nozzle
1- Sony new model tips that are like foam
2- Sony hybrid tips
is wm1a a good pairing for phantom ?
So I used this as an excuse to stop by BestBuy to try the WM1A with my Phantom. But this time, I was better equipped with @San Man's 4.4mm Bal Ares II cable, and his 4.4 to 3.5 adapter. So I was able to compare the SE and Bal. First thing I tested was the hiss, and there is definitely a hiss that is very very mild. In my standards, its almost negligible. I think the hiss may be a fraction lower than the hiss I got on Zeus+1Z.
Moving on to the sound, please take my impressions with caution, as I wasn't familiar with any of the tracks on the 1A Demo unit... Of all the DAP's I have tried the Phantom with so far; LPG, R6, ZX300, WM1A, I think the 1A is my favourite of the lot. Sure LPG and Hugo2 sound more detailed and engaging. But for me personally, those 2 devices make the Phantom more bright, as they don't help smooth out the lower treble peak. 1A may not be as detailed as those 2 DAPs, but with its airy stage and a pleasant signature, I felt it paired excellently with the Phantom.
Who here is using the LX with the DX200? And what's your favorite amp with it? Upgraditis strikes again...
I am using LX with the DX200. AMP4 is my fave but I know it's not available anymore. They will be releasing AMP8 soon which is also 4.4mm. I'd put AMP3 in 2nd, still a great amp with more energy and less spaciousness compared to AMP4. Depends what you're looking for. Do you use SE or balanced (2.5 or 4.4)?
Darn it, that is the Hugo2 and LPG probably out for me. I will try them if I find an opportunity, but I think any sort of hiss would drive me insane. Although it depends a bit on whether or not it is audible during very silent sections of classical music. (Come to think about it, I have no idea about hiss, as my AK70 simply doesn't produce any.)Both Zeus and Phantom have a hiss on all 3 Sony DAPs: 1A, 1Z and ZX300. But I would say the hiss is very mild. Far from what I have on Hugo 2 or LPG.
Thanks for the impressions! I think the 1A might also be more to my liking. I switched out the Final tips because I struggled with the seal a little, but also because those tips can be a bit more aggressive in the treble. Also switched from SE to balanced on my AK70 which makes the treble more laid-back. While I see merit in going for SE (I notice it especially in the tone of brass instruments), I just prefer how smooth it sounds from balanced. Paired with the Ares II 8-wire it all seems to come together for classical music with a big, airy stage and exceptional tonality. Really loving the Phantom!So I used this as an excuse to stop by BestBuy to try the WM1A with my Phantom. But this time, I was better equipped with @San Man's 4.4mm Bal Ares II cable, and his 4.4 to 3.5 adapter. So I was able to compare the SE and Bal. First thing I tested was the hiss, and there is definitely a hiss that is very very mild. In my standards, its almost negligible. I think the hiss may be a fraction lower than the hiss I got on Zeus+1Z.
Do you have any more details on the ZX300 pairing? I'm planning to get one soon and am a little concerned that it might not be a good match for the Bravado.So I used this as an excuse to stop by BestBuy to try the WM1A with my Phantom. But this time, I was better equipped with @San Man's 4.4mm Bal Ares II cable, and his 4.4 to 3.5 adapter. So I was able to compare the SE and Bal. First thing I tested was the hiss, and there is definitely a hiss that is very very mild. In my standards, its almost negligible. I think the hiss may be a fraction lower than the hiss I got on Zeus+1Z.
Here you go, my right ear with the same connector that aaf evo has (in black) :-
and another from a different company, though regulars should be able to work out who they are from, just didn't want to get into trouble by mentioning a competitor on the ee thread! Here you go :-
So you can see the differences I hope. Despite the looks the seal is pretty much the same.
been thinking lately of selling my nt6 and maybe (i said maybe @Wyville , so hold those demons) buying phantom come next BF sales
You know, the fact that I only need to charge my WM1A every three days or so is so convenient
as well as the UI
the instant file transfer on MacOS
the durable 4.4mm balanced plug, the...
Zeus has too much hiss on the LPG, but Phantom is ok. The is hiss, but doesn't bother me much, and I hate hiss.Darn it, that is the Hugo2 and LPG probably out for me. I will try them if I find an opportunity, but I think any sort of hiss would drive me insane. Although it depends a bit on whether or not it is audible during very silent sections of classical music. (Come to think about it, I have no idea about hiss, as my AK70 simply doesn't produce any.)
You know you want to...Well that backfired quickly!
Why try to postpone the inevitable?...
