Jazzi
- Feb 28, 2015
I can certainly vouch for the pwaudio no5. Great cable!well seeing you went for zeus/sp1000 i bet you are fine on cash so buy this lovely and relatively cheap cable that pairs well with XR
pwaudio no5 (4-braid)
or go all in and get the pwaudio 1960s (2-wire) which is currently my dream wishlist cable
Personally i preferred the redcore.
I also felt that the twau wasnt the most ergonomic cable....
Design game strong
If it's for Zeus XRA, one of the best cable options is the 1960 2-wire. Just because you need a really warm cable to fill it up and create a more natural sound, so that would be a pretty easy choice for me.I love except the switch that I will have preferred in white
You do not have breath with sp1000?
I find the black too stubborn
the dilemma for the cable is to choose between 1960s in 2 wire or Leonidas.
I see. K10 might sound slightly darker than what you are used to with 1960s for rock and metal. If budget isn't an issue, I would actually recommend you get a silver cable just for the K10. It would be a hassle to switch cables anyway.
If you can only get one cable, and it must be either 1960s or Leonidas, I would not be able to give any recommendations, as K10 and Zeus are two very different sounding IEMs.
If you don't mind getting other cables, I would like to recommend HanSound Zen 8 and Effect Audio Ares II. They are not flagship cables, but they are both very good copper cables with an slightly analytic taste. They would bring out the edges in the music for k10, and add warmth to the Zeus signature.
The new shell design is more streamlined. The Adel version did not get a refresh only the non-Adel.I really like the stealth black Zeus XR @olddude has. It looks very low-profile, and classy at once. The new shell-revision looks more compact too.
