Dingding123
Member of the Trade: Jeff's Audio Solutions
@Deezel177 , regarding cable pairings for Zeus, here are my personal impressions.
Effect Audio:
Eros II (8 cable bespoke) - Good soundstage, good extension at the treble, slightly warm lower mids, slightly attenuated bass. Quite ergonomic.
Lionheart - increases subbass by a little bit, otherwise unremarkable. Very ergonomic.
Heracles - very holographic, very beautiful, very vivid sound, very hard to come-by too. Quite ergonimic.
PW Audio:
1960 4 wires - Holographic soundstage, excellent imaging and layering, fluid and smooth bass, very transparent treble, can be overly sharp. THE ultimate cable if the highs were less sharp. Can get dirty if you have oily skin/sweat a lot.
1960 2 wires - Enhanced bass. Smooth, emotional and warm mids. Attenuated treble, reducing the sparkle while maintaining the transparence and layering. Sounds "cozy" compared to 4 wires, but smaller soundstage. Quite ergonomic. Can get dirty if you have oily skin/sweat a lot.
No5 - smooth and rounded transients, slightly warm mids. Quite ergonomic.
Han Sound:
Redcore - Transparent and excellent layering and imaging. Clean, unpolluted mids and fairly large soundstage, very controlled bass with a lift in volume.
Aurora - Forward mids, really sweet. Good depth, but not as wide as the Redcore. Soundstage-wise, Redcore vs Aurora is like 1960 4 wire vs 2 wire. Very ergonomic.
Lagoom - Sharp highs, peaky treble on the Zeus, not recommended. (I'm not usually sensitive to loud trebles but the Lagoom is just too intense). Very ergonomic.
Agni - Bassy, but doesn't do as well as the PlusSound GPC 4 wire. Strangely for a silver cable, Agni kills the treble, and increases mid bass. Improves hissing on some sources. Very ergonomic.
PlusSound: (x4 Echo series, generally not ergonomic as cables are stiff)
Tri-metal - sounds similar to Lionheart, slightly more subbass, warmer mids.
Gold-plated copper - strong bass, warm, but attenuates treble. Improves hissing on some sources.
Silver gold mix: sharp and intense treble.
Whiplash: (generally not ergonomic as cables are stiff, and I find the workmanship near the 2-pin termination rather crude...)
TwAg V3: similar to Eros II, but colder and faster decay, very silver-like.
TwAg V4: don't... just don't...
YMMV, but Zeus does benefit greatly from good cables as it is so detailed and sensitive.
Also, Zeus is rather malleable to burn-in. What you burn it in with will determine the sound signature. Since you use Logic X, you can experiment with different noises/tones using the test oscillation plug-in.
Effect Audio:
PW Audio:
Han Sound:
