- Sep 20, 2009
After an evening with the Raven I can share some bulletpoints :
- the fit is OK given the size, I haven't found a tip for long lasting comfort but I'm not Allegro'd by the shell immediately so kudos for that
- the cable is quite stiff and not that ergonomic, cable slider is too slidy and falls down often. Hero's slider was hard to move but at least did its thing properly.
- puck case has nice heft to it and is definitely the most premium compared to 64audio or FiR variants, but is a little bit too small to fit the Raven and its thick cable without fear of shells knocking on each other. Mesh pouch won't fit, too. Craft ears case can fit the IEMs perfectly - they sort of click into the cutouts and are far away from each other. The cable is on the thicker side so it's tough to fit it inside but it's doable. Custom art updated case has the perfect amount of space for both the shells and the cable without coiling it too much. My current go to.
- signature EE driver flex is still here, not an issue for me but some may by bothered by the initial crincle.
Sound impressions are to follow I'm happy that second week of December is finally here and I can enjoy this set at last!
