Yeah I would say try M on the SpinFit. I also usually use L for final E and I’m using M for CP155Are they the same size as the „stock“ tips (Final E)?
I am using the stock tips in „L“, will the SpinFit in L be the same or do I have to chose larger/smaller ones? Thanks
EDIT: It seems the SpinFits are a little larger, so Final-E in L would be more likely SpinFit in M?
Final E, size L:
SpinFit, size M:
- L = height 10mm, outer diameter 12mm
I assembled this together from different sites (Amazon, 46 Audio). Not sure if reliable.
- M = height 11mm, outer diameter 12mm
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
