Does LX SE have any improvements/changes to technicalities or is it just the tuning that has changed?
Empire Ears - Discussion & Impressions (Formerly EarWerkz)
- Thread starter Jack Vang
AboveNBeyond
Minor tuning change only.Does LX SE have any improvements/changes to technicalities or is it just the tuning that has changed?
- Dec 26, 2019
Would’ve been able to read it but gave up after the 8th advertisement pop up blocked most of my phone screen.Our Bravado MKII article is now also available. An article by @Virtu Fortuna
https://www.headfonia.com/empire-ears-bravado-mkii-review/
I’ve been listening the last couple days to Odin with PW No 10 cable. Definitely not a downgrade. The Stormbreaker is fixed to the LX.
Xinlisupreme
@Progisus Are you using no.10 4wire or 8wire?I’ve been listening the last couple days to Odin with PW No 10 cable. Definitely not a downgrade. The Stormbreaker is fixed to the LX.
GotchaPine007
Just the 4 wire.@Progisus Are you using no.10 4wire or 8wire?
If you like EDM, would recommend giving Marsh’s new Heaven EP a try. Nice and deeeep. Liberator (esp the extended mix) is particularly mesmerizing.
Enjoying it with my LXSE (which I suppose I should clarify is the “OG” LXSE lol)
The EP is also available on Apple Music in 16/44, if you’re interested.
- Dec 26, 2019
Ahhh... the memories.That sounds suspiciously like Odin,
To be fair my local dealer told me that I probably wouldn't like Odin because it had dual DDs like the LX.
KuroKitsu
Feels like ages agoAhhh... the memories.
named name
riverground
That really is quite the beautyI caved in and specifically hunted down lucky number 13. Very satisfied with this procurement, awesome sound and looks beautiful. Would be even better if the design was built with recessed 2 pin connectors instead of flushed.
superjohny
- Jun 4, 2005
just got my odin a few days ago. saw someone says odin being comparable to utopia, so i set high expectation but seems a bit disappointment to me after hearing. maybe because it needs some time break in. but certainly what I hear from now out of Odin is not comparable to utopia. maybe because i was using utopia with dana cable and SP1000 and with Odin, i only have stock cable and BTR5 while waiting for cayin n8 romi mod to arrive.
I was thinking about changing stock cable to tralucent uber gen3 cable but then realized the stock stormbreaker cable sells for $1299????what??????
should i change cable for ODIN?? if i decided to change, anyone interested purchasing my stormbreaker?
Why don’t you use the SP1000? The BTR5 definitely wouldn’t get the most out of Odin.
Xinlisupreme
Rainy day… hero+M8 and good music.
Burnin isn’t finished but sounds amazing with M8 and Penon OSG
