- Jan 15, 2015
Customs do not have tips...As long as the tips don't come off in your ear
So if you remove customs and something comes off in your ear - you got a problem!!
secret advantage of customs—not having to carry gd tweezers in your bag for when a tip inevitably pops off and needs fishing out
@forbiddenbeat what sound changes/improvements are yoy seeking from the cable for your Valkyrie ? budget ?
I have a guy that makes cables in the UK that rival any cable to can get here and he charges much less. He made me one for Valkyrie and Legend X. He would make you a killer wire for $600 ish... Level 4 LitzI think more extension and sound stage, if possible. This might sound dumb, but I really enjoy 8-wires and their heft, so I'm really just trying to justify a reason to get an 8-wire (I have a Janus D for my Phantoms and love it). Budget is $1500, less is better of course.
Who is this?I have a guy that makes cables in the UK that rival any cable to can get here and he charges much less. He made me one for Valkyrie and Legend X. He would make you a killer wire for $600 ish... Level 4 Litz
Skedra. He has an audio Blog as well. www.vikingaudioblog.comWho is this?
I used my custom Valkyries with a PWAudio 1950s cable and the sound was superlative! (love that word), I know that is an expensive cable, but my point is it is a copper cable, where the eros II (which I use, the stock), is copper/silver hybrid. So investing in a quality copper may be an option. i demoed the PWA Monile at canjam, and that sounded fantastic on the Val!, but again, that is a $1,000 cable...Asking this again – does anyone have a cable upgrade recommendation for the Valks? I was thinking of getting the Eros II+ 8-wire, but not sure if there is another option from EA that might be a better fit. Not looking to change the sound signature, just more of the goodness.
I wouldn't...I owned the Cleopatra 4 wire, and while it is a fabulous cable, the 8 wire version is only slightly better (to my ears); the Cleopatra is VERY smooth and does not suit the DD of the Valkyries at all IMHO: I would go with an 8-wire eros II (or equivalent), or even a quality 8 wire copper based on budget and taste....Thank you! I'll check out the PW cables. Someone from Effect Audio recommended the Cleopatra Octa, which looks like it might fit what I'm looking for. Now, to decide whether to spend the money.
