cel4145
I use an ODAC and Schiit Asgard 2 with my setup. The ODAC with the 3.5mm audio output is very tiny, so doesn't take up an appreciable amount of space to have both in your setup.
Because I need a dac, headphone jack and headphone amp, volume control and means of switching between speakers and headphones in the device(s), adding a USB to SPDIF convertor wouldn't leave much funds for the other functions, so the Nuforce U1925 is probably not a practical investment at my price point. I appreciate the pointer though.
The NFB 15.32 was actually my first choice. I was in the process of ordering one with the TXCO upgrade when the good people at Audio-GD told me that it wasn't guaranteed to work with the USB 3.0 ports on my late 2012 iMac. I was also told that the SPDIF port should work fine, but since that port max-es out at 96/24 on my iMac, and with the added issue of computer noise (since mine is not a dedicated music server), I didn't want to go in that direction. But yeah, Audio-GD is a good suggestion.
Would you be kind enough to identify the specific hi-fi tuning supreme fuse needed for a pair of Emotiva Airmotiv 4, how many and where I can find instructions for changing out the fuses?
I've been using my new 15.32 for almost 3 weeks, no regrets.
Feel no need to going back to using the headphone amplifier on my Essence STX (AD797BR).
What! You've abandoned your STX for another dac/amp now? I knew you got the 15.32, but your STX must be upset
