The collection ranges from Fourte, A18T/12T and Z1R as the oldest to xe6, Annihilator, Mentor, Trifecta and Ragnar as the most recent, which some “classics” like Traillii, Jewel, Mason FS, Erlkonig, Odin, EVO in between. And I'll stop here .
Sorry, I missed your question. I’m currently traveling and I brought the M9. At home I’m using the SP3000, 300 MAX, N7 (often with C9), and sometimes desktop gear.
You can order directly from Elysian but most folks opt to order through a retailer, such as Musicteck or Elise Audio. You would then work through the retailer for CS, warranty claims and repairs.
Has anyone been able to get the SpinFit Omni tips onto the Anni? It seems practically impossible. I gave up trying after a while and turned to the SednaEarfit lights.
I used Omni on Odin and there was already a big problem to deploy them. I didn't even try it on Anni, because it's still wider. I also use earfit light (short) and I am absolutely satisfied with them in terms of comfort and sound.
Glad I'm not the only one that couldn't get the Omni's to work! I received a pair yesterday and spent way too much time trying to get them on. Gave up and am back to W1s. The Omni have been relegated to the Xe6.
I’m using the SpinFit Omni tips with great results and they are easy to install if you slightly warm or stretch them before fitting the tips. However, you should be careful to not stretch them too far because the guide tube will rip.
